xj650 noise
Discussion in 'XJ Technical Chat' started by lancial, Aug 17, 2011.
  1. lancial
    lancial New Member
    so i just did a top end on an 82 xj650 and everything seems to be ok, well as soon as i started it i heard a loud noice around the starter and stator and im not sure how or what it is. any help would be appreacated
  2. MiCarl
    Description of the noise would be helpful.......
    If it's a howl it's like the starter clutch isn't disengaging.
  3. yamaman
    yamaman Member
    Staten Island, NY
    the timing pointer that passes the pickup coils might be making contact. Just did my top end and as soon as I started it was clear. I'm sure you turned the crank a million times when doing the valve clearances, and probably bumped the pickup w/ the wrench
