xj650 petcock vaccum line
Discussion in 'XJ Technical Chat' started by darrin, Jul 26, 2015.
  1. darrin
    darrin New Member
    Alberta canada
    Where the heck does this vaccum line hook up too!?
  2. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    To the vacuum port on the carb. Not sure which one for your bike. Buts it's probably the one that doesn't have a cap. That is if you have a stock petcock.
  3. BigT
    BigT Active Member
    Airville, Pa
    Usually it connects to the number 3 intake manifold, but it really does not matter which one as long as the other 3 are capped off.
    The reason for hooking it to #3 is that #3 is the master carb and the vacuum from it is used as baseline for calibrating the manometer that was used during initial setup before delivery to the first owner. A trivial point really, but nice to know.
    Luis likes this.
  5. darrin
    darrin New Member
    Alberta canada
    Thanks! So #1 is the left side of engine if your sitting on the bike? So second one in from the right side
  6. k-moe
    yes.
    darrin likes this.
