XJ650 Start up rev issue
Discussion in 'XJ Technical Chat' started by Daniel Diblasi, Feb 16, 2018.
  1. k-moe
    Did you let the bike fully warm up before blipping the throttle?
    And MERGED.
  2. Daniel Diblasi
    Daniel Diblasi New Member
    Ohio
    Yes its an xj650 but i think the guy I bought it from put a xj750 tank on it. The vacuum line is connected to the manifold boots. I will test he petcock and gascap filter to see if that does anything.
  3. Daniel Diblasi
    Ohio
    yes
  4. Daniel Diblasi
    Ohio
    yes i have a manual petcock, i have a xj750 tank on a xj650.
  5. XJ550H
    you should put caps on the ports not run vac line from port to port. and by manual I mean not vacuum operated.
    gas cap has a vent not a filter but clean it.
    750 has 1.8 reserve tank you need to have 3 gallons (over 1.8) in there for to run on on.
  6. k-moe
    There's also about a quart of gas that sits below the petcock, and will never get drained unless you tip the tank over.
