Xj650 turbo carbs
Discussion in 'XJ Technical Chat' started by murray9982, Apr 7, 2016.
  1. murray9982
    murray9982 New Member
    Hi, it,s been a while ,but back again with new project. I started cleaning and refurbishing xj650 Turbo Mikuni carbs and have noticed that carbs 1 & 2 have 127.5 main jets ,while 2 & 3 have 137.5 main jets . From my searches ,this seems to be correct , although not listed this way by Yamaha . I would like to confirm that this is correct, and appreciate any info on why it was done this way , cheers , Murray
    On the Turbo 2 and 3 need to run richer in order to keep the combustion chamber and valves cool.
  3. murray9982
    Thanks for the reply. I thought it most likely something like that ,will put back together when
    parts arrive from Len
  4. murray9982
    Actually , that was 132.5 2 & 3 , mistype , no matter
  5. a100man
    a100man Well-Known Member
    Bedford, UK
    K, not just the Turbo I think. This comes up quite often and most are like that..
  6. k-moe
    I am aware that it's not just the turbo that has richer jets on 2&3.
  7. XJ550H
    from
    http://xjbikes.wikidot.com/carb-specs
    Years & Models: 1984 XJ550L Maxim models
    Carb Manufacturer: Mikuni
    Carb Series: BS32
    Carb Model ID: 5K500
    Main FUEL Jet Size: #105 (cylinders #1 & 2)
    Main FUEL Jet Size: #102.5 (cylinders #3 & 4)
    Pilot FUEL Jet Size: #40
    Main AIR Jet Size: #70 (non-removable, in carb throat)
    Pilot AIR Jet Size: #155
    AIR COMPENSATOR Jet Size: not used.
    Starter FUEL Jet Size: #42.5 (non-replaceable, in float bowl)
    Main jet NEEDLE ID: #4CP7-3 (cylinder #2)
    Main jet NEEDLE ID: #4CP3-3 (cylinders #1, 3, and 4)
    Main needle JET Size: #N-8 (the main needle JET is also known as the "power valve" or "emulsion tube").
    Fuel Level in float bowls: 3mm +/- 1mm (.118" +/- .039")
    Idle RPM's: 1,200 rpms
    Years & Models: 1983 XJ750E-II models
    Carb Manufacturer: Hitachi
    Carb Series: HSC33
    Carb Model ID: 29R00
    Main FUEL Jet Size: #105 (cylinders #1 & #4)
    Main FUEL Jet Size: #102 (cylinders #2 & #3)
    Pilot AIR Jet Size: #225
    Starter FUEL Jet Size: #43 (non-replaceable, in float bowl)
    Main jet NEEDLE ID: #Y-17
    Main needle JET Size: #3.2mm (the main needle JET is also known as the "power valve" or "emulsion tube").
    Fuel Level in float bowls: 5mm +/- 1mm (.197" +/- .039")
    Idle RPM's: 1,050 rpms
    and of course the turbo
    Years & Models: 1982-3 XJ650LJ/LK Turbo Seca North American models
    Carb Series: BS30
    Carb Model ID: 16G00
    Main FUEL Jet Size: #127.5 (cylinders #1 & #4)
    Main FUEL Jet Size: #132.5 (cylinders #2 & #3)
    NOTE: the yamaha parts books reference the use of #125 main fuel jets. Original carbs that we have explored have the #127.5/#132.5 combination of jets as shown above.
    Pilot FUEL Jet Size: #35
    Pilot AIR Jet Size: #170
    NOTE: the yamaha parts books reference the use of #165 pilot air jets for the 1982 models, and #155 pilot air jets for the 1983 models. Original carbs that we have explored have the #170 jets as shown above.
    Starter FUEL Jet Size: #30 (non-replaceable, in float bowl)
    Main jet NEEDLE ID: #4DPS39
    Main needle JET Size: #O-6, #318 style (the main needle JET is also known as the "power valve" or "emulsion tube").
    Fuel Level in float bowls: 2mm +/- 1mm (.08 +/- .04 inches)
  8. a100man
    Bedford, UK
    Of course..
