XJ650J Steering Bearing Install It Can't Be This Easy.Is It?
Discussion in 'XJ Technical Chat' started by StahlMaster, Aug 27, 2010.
  1. StahlMaster
    StahlMaster Active Member
    Southgate, Michigan
    I'm installing new steering head bearings on my XJ650J Maxim. The picture will show what I believe to be the old races and the new races installed. Is it ok to have the new upper race sit slightly above the head? I pressed it in as far as it will go. Also, did I remove ALL the old parts? I do have the 38 little balls and 4 pieces which sandwitched them in the head. The reason I'm asking is that I think the races came out way to easy.
    D
    http://smg.photobucket.com/albums/v180/ ... 0Bearings/
  2. wizard
    As long as it is in level it will push down when you torque the nut.
