XJ700 Forks
Discussion in 'XJ Technical Chat' started by SLKid, Nov 8, 2009.
  1. SLKid
    SLKid Active Member
    Troy, Va (Charlottesville)
    So one of my winter projects for the bike is going to be doing the forks. They're in BAD shape. Not bent, but all the seals and cap bolts and o rings will need to be replaced and that is getting pretty pricey.
    I see forks on ebay for our bikes at nearly half the price of my rebuild. So i'm thinkin about it.
    Which models are compatible with my 700?
    Even if I can just strip the good parts off the ebay forks and buy the other parts from our resident chacal I still think that'd be cheaper.
    -Chris
  2. MiCarl
    What do you suppose the odds are that eBay forks aren't also in need of rebuilding, or will be soon?
  3. Desinger_Mike
    Desinger_Mike Member
    Eastern Pennsylvania
    My understanding is only 85/86 XJ700 will fit. The X forks are designed with air assist but it wouldn't hurt anything on a non-X.
    I have a pair in the garage, but they are slighly pitted and would need new seals too.
  4. SLKid
    SLKid Active Member
    Well see I wouldnt mind doin the seals. But my cap bolts are rusted through/ Those babies are 25 a pop! So maybe i should just go and rebuild em.. Pricey.. but you're right. The ebay ones will prob need a rebuild in the near future
