Xj700 maxim aircooled vacuum
Discussion in 'XJ Technical Chat' started by Stroker, Jul 7, 2021.
  1. Stroker
    Stroker New Member
    Norway
    Hi. What is your normal vacuum reading when doing a carb sync?
  2. Dan Gardner
    Minneapolis, MN
    This was the reading from last time I synched the XJ700N:
    Not saying its correct...
    Mostly people say that the actual number doesn't matter (and it changes with RPM anyway) - but that what's important is that they are the same.
  3. Stroker
    Stroker New Member
    Norway
    Thank you
  4. JCH
    JCH Active Member
    seattle wash
    No more then two line inclement between cylinders I believe and the closer the better.
  5. Stroker
    Stroker New Member
    Norway
  6. Stroker
    Stroker New Member
    Norway
    This is where I am , not adjusted anything yet. 3 turns out on all 4 carbs
  7. Mechanic1978
    Mechanic1978 Active Member
    NOYB
    not too bad off the start...:)
