XJ700 Maxim engine Code IDs
Discussion in 'XJ Technical Chat' started by chicks007, Oct 14, 2015.
  1. chicks007
    chicks007 New Member
    Dartmouth, NS, Canada
    I suspect this might be a quick answer for the tech savvy out there, I hope.
    Love the XJ Bikes, I've been riding one more than 25 years. Actually I have two 1985 XJ700 Maxim Ns, one I road for a long time and now for parts and another I picked up a couple years ago. Frame serial numbers are very close with the "1FH" in it for a Canadian import for both bikes. However my first bike has the Frame/Model ID code and engine ID code the same "1FH" in the number but my second 1985 XJ700 Maxim has the Frame/Model ID code of "1FH" and the engine ID code of "15T" yet the engines look identical. With a little investigation on this site the "15T" comes up as a ID code for a 1981 XJ750. Can someone out there let me know if a "15T" engine ID code could be still an XJ700 engine, is there a "cc" stamped on the engines somewhere?
    Thanks, Carl
  2. BigT
    BigT Active Member
    Airville, Pa
    The cc is stamped on front of the block under the head between the 2nd and 3rd exhaust pipes.
  3. k-moe
    The engines are a direct swap. The 15T code is not going to be for a XJ700 engine. You have a transplant from a Canadian 1982 Maxim 750.
  4. chicks007
    Thank You, I will look closely for the cc. Since I now know I have an 82 XJ750 engine, is it worth saving any XJ700 engine parts from my other XJ700 for it? I guess I shouldn't be surprised those engines could be directly swapped.
    Cheers.
  5. Stevetriv
    Stevetriv New Member
    nsw, Australia
    Can anyone please tell me where the engine I.D. number is located ?
    Thanks. Can't find it anywhere
  6. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    Right side of the case just above the clutch cover.
  7. chacal
    And it's stamped into a flat, "ribbed" pad (the ribbing, like the edges on a coin, makes changes/counterfeiting easy to detect).
