xj700 maxim x compatibility
Discussion in 'XJ Technical Chat' started by SAUERKRAUT, Mar 27, 2019.
  1. SAUERKRAUT
    SAUERKRAUT New Member
    Canada
    Hey guys, new here,
    does anyone know if the maxim x rear wheel from a xj700 will directly swap onto a xj650 maxim regarding spline size and brakes etc. I like the solid wheel design. Any info would be greatly appreciated. Cheers!
      File size:
      46.8 KB
  2. Simmy
    Spline will mount right up. XJ650 Maxim apparently takes a different brake shoe than the Seca's and 700/750's.
    Best thing is to buy the brake backing plate to. Find the wheel from the 750-X, I can set you up with a backing plate if you can't find one but they are common.
  3. SAUERKRAUT
    Canada
    Thanks for the great info! happy about the spline comparability. Regarding brakes if I got the backing plate (I believe it’s what is pictured in this photo?) would I stick with the xj650 brakes? Or would I have to get a new rear drum brake assembly that’s from a xj750 maxim x? Cheers
    The brake is cast with the wheel, which is why you also need the backing plate. You will use the brake shoes and hardware from the model of XJ that the wheel came from.
    Chitwood likes this.
  5. Toomanybikes
    Tsawwassen bc
    Where in Canada ? It’s a big place.
    I have a couple of the Xj700n wheels and brake backing plates if you can’t find the “X” model wheel
  6. SAUERKRAUT
    Canada
    I’m over In Winnipeg. Do you have a front wheel aswell? I would be interested in that setup aswell. Thanks
  7. Toomanybikes
    Tsawwassen bc
    Yes have fronts and rears with all the fixings.
