Xj700 oil and filter kind?
Discussion in 'XJ Technical Chat' started by Z320moto, May 1, 2016.
  1. Z320moto
    Z320moto New Member
    New York
    Hello I managed to get my 1985 xj700 carbs out and now finishing up on bench synchronising. While I'm doing this I would like to do a oil and filter change. So here is what I was thinking, what are you guys runing on your xj700? What oils have you used and and liked or not liked. What filters are you running?
  2. mrdawson
    mrdawson Active Member
    Wisconsin
  3. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    I'm using Mobil 1 synthetic in my XJ700 and have had no problems at all. However, I think any high quality oil with the JASO rating will be fine. There are a lot of folks that swear by Rotella. I am using a Fram filter because it comes with the o-ring. I think Wix filters also include the o-ring. Can't remember the Fram number, but someone will post it here.
  4. tabaka45
    Brunswick, Georgia
    Fram filter is CH6003. use a cross reference for other brands, but check and make sure the o-ring is supplied unless you want to reuse the one you have.
  5. PilotSmack
    PilotSmack Active Member
    Calgary, Canada
    I did the spin-on conversion, and run a Bosch 3300. I've never had any issues, even after a valve cover bolt holder exploded and released chunks into my engine, the filter caught them all.
    I use Castrol 4T 20W-50, but have been thinking about switching to the Rotella.
