xj700 Tire suggestions?
Discussion in 'XJ Technical Chat' started by idle_purr, Jun 27, 2023.
Tags:
  1. idle_purr
    idle_purr New Member
    NY
    Hello everyone, I recently ordered a new tire and by mistake I got one that was 110/90/19 but the label on the bike calls for one that is 100/90/19. I thought that it would be okay and really seemed fine after I put it back on, but after reaching highway speeds the front fender rubbed on the tire and gouged it pretty good.
    I was wondering if reducing the tire size to what the factory calls for would eliminate the issue? I assume it would but I just don't want to order the wrong tire, and would really like to avoid damaging another tire.
    Here is the link to the tire I am looking at.
    Can anyone please advise me if this tire would work, or suggest one that will. As of now I don't really see anyway to bring the fender up and it's a really snug fit, but nothing is bent or damaged. At the moment I just took the fender off.
    Thank you in advance!
  2. short_circutz
    short_circutz Active Member
    Sault Ste Maire, On, Canada
    I have 100/90 19 on mine (XJ750 Maxim)
    If you're willing to modify your front fender, maybe you can "slot" the mounting holes so you can raise it a bit further above this tire?
    idle_purr likes this.
  3. idle_purr
    NY
    I have the front fender off the bike at the moment, its all shaped specifically to fit around the forks, I was going to raise it with some washers but it's just not possible because there is not enough space between the mounting bracket and the side of the fork.
    I think I might buy a 2nd fender from ebay and modify the hanging bracket by shaving off the bottom lip where it cannot get past the fork. Then I can raise the bracket with some spacers.
    Or I am going to buy the right size tire as I am not sure how safe the current tire is after being chewed up a little.
  4. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    100/90-19 on both my XJ700 and XJ700X, perfect.
  5. idle_purr
    NY
    Which tire are you running?
    Do you think this tire (Click Here) would be sufficient? It is the correct size and it can go above 130mph, which I would not be doing anyway.
  6. Huntchuks
    East Rochester, NY
    I would imagine they would be good, personal preference as to the manufacturer. I just use the cheap Shinko 777 tires.
  7. short_circutz
    I have that exact tire on the front of my 83, soon to be followed by the matching rear so I can get rid of the crappy Spitfire II thats came on the bike, which I hate with a passion. Hated the Spitfire II that was on the back of my old naked 85 Venture as well.
  8. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    I firmly believe that keeping everything stock is the best option. I would go back to the correct tire size.
  9. idle_purr
    NY
    Yeah, I ended up purchasing the Dunlop 100/90/19 and it works like a charm.
  10. tabaka45
    Brunswick, Georgia
    On top of that, your speedometer is closer to correct with the proper tire.
  11. short_circutz
    With the 100, I find my speedometer reads abt 5km/h fast. Strange, as the outside diameter of the front tire is a bit larger than OEM now and should read slower, lol. 83 XJ750 Maxim.
