xj700n final drive removal??
Discussion in 'XJ Technical Chat' started by denbola, Mar 18, 2016.
  1. denbola
    denbola Member
    poole,dorset,england
    hi, whats the best way to remove final drive unit,with the rear wheel removed is it just the four bolts?? and will the driveshaft stay in the swing arm or pull away with drive unit, many thanks
    Yes it's just those four nuts. The driveshaft will stay in the swingarm (it's captured in the u-joint by a spring clip), but there is a spring that will fall out (it goes between the driveshaft and the final drive).
  3. denbola
    denbola Member
    thanks k-moe for your help, will remove this w/end
