xj700n starter grinds swapped starter still grinds
Discussion in 'XJ Technical Chat' started by joshs700n, Sep 16, 2013.
  1. joshs700n
    joshs700n Member
    mass
    i get this chopping noise if i hold the starter button long enough switched the starter still did it also my clutch slips is this my oil causing it? 10-40 synthetic valvoline motorcycle oil
  2. adrian1
    adrian1 Active Member
    Pls list your bike details in your signature. If no evidence clutch has been refurbed in living memory then its probably due for a rebuild...(after you have confirmed the cable is not binding). How long have you owned the bike? How long are you holing the starter button for?
  3. joshs700n
    joshs700n Member
    mass
    got the bike 2 months ago it had been sitting outside for 2-3 years it always starts on just a touch of the button
  4. bigfitz52
    Start by changing the oil. 20W50 non-synthetic motorcycle oil.
    10W-anything in XJs is for cold weather.
  5. joshs700n
    joshs700n Member
    mass
    Hi im scared I've heard oncd you go synthetic you never go back. how cold weather cuz its startin to get cold now 50
    degrees I have 18,000 miles and 150 in every cylinder
  6. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    use the right weight oil! and these bikes just plain don't like synthetics. and cold is regularly running in the 20's I believe. not at home, can't look it up....
  7. bigfitz52
    "Cold" means it stays below 40F most of the time, and for that Yamaha recommends 10W30.
    But use a non-synthetic, motorcycle-spec oil.
  8. jmilliken
    Dillsburg, PA
    Thanks Fitz! Is there anything you don't know?
  9. bigfitz52
    ALL SORTS of stuff. Which is why I have reference materials.
  10. k-moe
    That is a rumor that has no bearing on reality.
  11. joshs700n
    joshs700n Member
    mass
    will it run different like engine wear more when i race the bike or just in general if i switch to non synthetice motorcycle oil like run hotter? i ran the same oil in my dads 1985 maxim x 5valve and never had a problem
  12. bigfitz52
    The problem (in general) with synthetics is that they're literally "too slippery." At least for certain older mechanisms.
    Truth be told, some of these bikes can get away with running semi-synth or full synthetic motorcycle oil; but a large majority of them cannot. The starter clutch is usually where the issue arises.
    So to eliminate it as a cause of the problem, we're recommending a switch to conventional oil until you have it sorted out. Obviously, if you change the oil and the problem goes away, then there's the answer.
    It also might not. But it needs to be eliminated.
    Per Yamaha, oil/temp specs: 20W40 from 41F up; if it's truly cold (32F) then 10W30 which can then go up to 59F. (Not above.) If you're riding in generally above 40 temps, stick to 20W basis weight oil. Since 20W40 is hard to find, you can run 20W50 with no issues.
    Now back to the heart of the problem:
    Keep in mind how the starter clutch works: it relies upon the "overwhelming" force from the spinning starter to cause the rollers to "grab" the inner piece. If the starter isn't spinning with enough "oomph" it will cause your symptom.
    There are other possibilities besides the starter itself; the original solenoid on these bikes has mechanical contact points inside it. If burnt/corroded it's very possible for them to carry enough current to spin the starter (any starter) but not to spin it with full force. Are you still running the original solenoid?
    What shape is the big cable from the solenoid to the starter in? Any green corrosion inside the sheath? Is the new starter NEW or just eBay new-to-you?
  13. joshs700n
    joshs700n Member
    mass
    yeah its everythings original and that starter motor is from the other maxim x motor i put the original starter back because the problem still occured anway also when i got the bike the color of the oil in the window looked brand new it also did it with that oil in it and the clutch also slipped the same i dont know what kind of oil it was. My dad had a candyapple red xj700n maxim out of the showroom in 1986 it was a leftover with 1500 miles he said he put straight 40 weight oil in it and after that it smoked when he first started it he raced it alot too outran a cop at 120 mph with his friend on the back
  14. bigfitz52
    All of which has absolutely nothing to do with the problems (if any) with your bike.
    Put the right oil in it and get back to us.
  15. joshs700n
    joshs700n Member
    mass
    does anyone know if I can put the maxim x clutch in the aircooled model 700
  16. bigfitz52
  17. jmilliken
    Dillsburg, PA
    no. they are completely different.
  18. chacal
    The XJ700 air-cooled and water-cooled models use the same clutch components except for the springs.....they are stiffer on the water-cooled models, but will interchange.
