XJ700X carb issue and high RPM's
Discussion in 'XJ Technical Chat' started by Derrek Woodard, Sep 6, 2024.
  1. Derrek Woodard
    Derrek Woodard New Member
    Pampa, texas
    I had bad throttle shaft seals. So I decided to replace all seals and did a complete carb rebuild. I got the rack back on and synced perfectly. The bike starts at the touch of the switch and idles perfect, no vacuum leaks. I rev it up and rpm's drops back down quickly. The problem is when I take off to accelerate, the rpm hangs making shifting rough. My question is, why does it start and idle fine with no hangs, but rpm's will hang while driving?
  2. Franz
    Standard airbox or pods?
  3. chacal
    Have you done a running (vacuum) synch of the engine yet?
  4. chris123
    chris123 Active Member
    Benicia, ca
    Something I’m having the same issue with. In my case I don’t think I had the bike warmed up completely prior to setting my idle.
    Rooster53 likes this.
  5. Derrek Woodard
    Pampa, texas
    It has a standard airbox. Uni air filter.
  6. Derrek Woodard
    Pampa, texas
    I used a motion pro sync gauge. It is in perfect sync. I rev the engine up and it drop down to idle fine no hangs, and goes back to regular vacuum.
    The only time it hang is when I drive it. This a first strange case for me.
  7. Zest
    Zest New Member
    MS
    New member question, maybe I can ask it here. I got the quads off for the 4th time, 85 xj700n, disassembled the rack, used impact screwdriver to remove rack screws! Have they got to be that tight to prevent changes when reinstalling carbs? I got high idle, also.
  8. Bryce W
    Bryce W Member
    Virginia
    Hanging idle can sometimes indicate a running lean condition, maybe take a look at the plugs and see what they look like. Check some of the simpler things first. And yes, the rack screws are very tight, at least on mine.
