XJ700X o-ring under clutch lever
Discussion in 'XJ Technical Chat' started by Dannymax, Feb 8, 2012.
  1. Dannymax
    Dannymax Member
    East central NY
    There is a small o-ring under the clutch lever which is shown on the fiche as part #5, but none under the brake lever (altho there is a machined groove which would accomodate it). And there isn't one shown on the fiche for the brake side..
    Is this a safety issue of some sort?
    I like the idea of a little rubber cushion between the bottom of the lever and the master cylinder housing, it's nice protection from wear. Is there any reason I can't install one? Does anyone run one on the brake side?
  2. hogfiddles
    Hi Dan, it's just there to help keep the lever from rattling and being loose.
    Dave
  3. Dannymax
    Dannymax Member
    East central NY
    Yeah, that's what I figured....when I removed the original brake lever there was a wear groove on the bottom which the o-ring would probly eliminate. Think I'll bring the new lever to the local A/P and see if they have an o-ring that will fit.
    You know....if it's not perfect then it just ain't right! :roll:
