xj700x valve pads/shims
Discussion in 'XJ Technical Chat' started by Spoodle44, Apr 25, 2015.
  1. Spoodle44
    Spoodle44 Member
    Raytown, MO USA
    If I get a shim kit with 7.48 mm shims will it work with my X? I need 18 for now and may have to swap out some a second time so a kit makes sense... if they fit.
    Thanks in advance
    D
    You are much better off buying (or trading for) the shims that you actually need, even when you need so many at once. In a kit you will end up having 1/2 to 3/4 of the box go unused if you only have the one motorcycle.
  3. Kenz
    Kenz New Member
    Washington State
    I agree. Take your measurements and get what you need. I went down to my local Yamaha shop and they were able to get them for me. Post the sizes you need, someone may have them laying around. They are spendy little things though.
