Xj750 CARBURETORS
Discussion in 'XJ Technical Chat' started by Codysc843, Mar 24, 2020.
  1. SQLGuy
    SQLGuy Well-Known Member
    OK, so why not plug it in? The other end of the cable connects to the alternator and to the battery.
  2. Codysc843
    Codysc843 Member
    Sc
    There ain't one.
  3. XJ550H
    the 2 jets you see from top of carb are air jets main fuel air jet and pilot air jet. they help fuel be drawn into carbs and be atomized for better combustion.
    I like to take them out so I can flush both ways you could spray cleaner and air down the jets but back flushing them may trap crud under them and end back in the passages.
    go to this thread and click the link it has cutaway carbs both mikuni and hatachi you will be able to see the passages you are cleaning and how air jets connect to fuel jets.
    It helps to understand the fuel air flow through the carbs when cleaning
    https://www.xjbikes.com/forums/threads/something-new-something-naked.36344/
  4. SQLGuy
    There ain't what? The cable is cut off at the alternator? Or the whole alternator is missing? Or...?
  5. Timbox
    Timbox Well-Known Member
    We might need some more pics if you would, that would really help clear up things here and get some definitive answers. If you are running the bike without a reg plugged in you are just asking for something to pop, melt or blow. I know it feels great to get her going and try to turn her, but please get a reg and get it plugged in. All the hard work you just did to clean the carbs so why add to a list of things that still need to be fixed.
  6. Codysc843
    Codysc843 Member
    Sc
    Well behind the tci box there's no regulator just a big adapter where I'm guessing the regulator would connect I installed new inline fuses so they should blow before the tci I don't have one to plug in it I'd have to search for one.
  7. hogfiddles
    You hope.
    there’s a gazillion of them on eBay.....
    https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/353008094326
    here’s just one.
    ifvyou don’t wanna use eBay, contact our member,
    750MaximSeattle ..... he’s probably got a bunch, too.
    dfox
  8. Codysc843
    Codysc843 Member
    Sc
    Is v77 the model or is there another brand and model such as hitachi such and such#123
  9. XJ550H
  10. XJ550H
  11. SQLGuy
    Guys, as I already pointed out, running with no regulator at all isn't going to "melt", "pop", or "blow" anything. There simply will be no output from the alternator, so the bike will be running off the battery until the battery is too low to power the ignition. Without alternator output, the headlight relay will never latch, so the headlight will stay off, which will make the battery last quite a bit longer.
    Cody, the regulator is not being the TCI, it's in front:
  12. SQLGuy
    That was supposed to say, "not behind the TCI"...
  13. Codysc843
    Codysc843 Member
    Sc
    Gotcha. Headlight was on after 2 rides not very bright but was on for sure
  14. SQLGuy
    What was done to this bike? Why is the regulator missing? Or is the regulator actually just relocated or something?
    Edit: I just realized that the diode block gets it sense feed directly from the alternator, not from the regulator, so the headlight relay will latch if the alternator is producing output regardless of whether there's output from the regulator... however, with no regulator there should be no field current, so no output from the alternator.
    Where do the cables that come out of your alternator go?
  15. Codysc843
    Codysc843 Member
    Sc
    Idk it's how I got it and the adapter is there but no regulator I'll probably order one
  16. SQLGuy
    I still don't know what you mean by "adapter". Adapter from what to what? Do you mean connector?
  17. Codysc843
    Codysc843 Member
    Sc
    Yep the big one near the tci where regulator plugs in
  18. Codysc843
    Codysc843 Member
    Sc
    Yall think itd be delivered quicker if I order one here or Ebay? shipping to charleston sc
  19. SQLGuy
  20. SQLGuy
    Len's shipping is usually amazingly fast.
