XJ750 Handlebar Switches Wiring Pinout/Diagram
Discussion in 'XJ Technical Chat' started by corey manshack, Dec 10, 2017.
  1. corey manshack
    corey manshack Member
    Gilmer, TX
    I need a wiring pinout/diagram with what colors go to the head light, low beam, horn, signals, and also everything on the right side switch. I purchased a universal set of switches for my bike and they have different connectors so now I'm stuck rewiring them correctly :(
    For Which Xj750?
    Maxim? Seca? XJ750RL?
  3. corey manshack
    Gilmer, TX
    I believe mine is the seca. I went ahead and did the painstaking work of taking the old controls apart and seeing what they went to and this is what I came up with.
    XJ750 Seca Right Side Controls -
    • Black/White & Green = Kill Switch
    • Black & Red/Yellow = Start Switch
    • Green/Yellow & Black = Brake Sensor
    • Aux Lamp
    Code:
    Brown/White                                Brown                   Red/Blue
    XJ750 Seca Left Side Controls -
    • Peach & Black = Horn
    • Front Lights (Green & Blue/Black = Low beam, Yellow & Blue/Black = High Beam)
    • Signal Lamps
    Code:
    Navy Green                                Brown/White                           Dark Brown
    Although there was also a yellow/red attached to the top of the signal switch inside the control on the yamaha that the universal switches didn't have. I attached that to the brown/white and it seems to work fine. Does anyone know what the yellow/red specifically is for?
    That's for the turn signal self-cancel. Change to a non-stock switch, and you'll lose that feaure.
  5. corey manshack
    Gilmer, TX
    Ok so is brown/white the ground and the yellow/red has to be grounded for the circuit to complete?
