xj750 head gasket on a xj650
Discussion in 'XJ Technical Chat' started by sybe, Jul 29, 2016.
  1. sybe
    sybe Active Member
    NYC - Brooklyn
    A friend of mine offered me his xj750 head gasket to see if i will fit my xj650. His theory is if the heads can swap why not the gaskets. Has anyone tried it? the markings on it is 5G2-11181-10 and i cant find anything online about swapping the gaskets.
    By part number it's not the same head gasket ( I think the thickness is different, which will change the compression ratio), but there is more than the head gasket that seals the head to the cylinders. You'll need a cam chain tunnel gasket, the YICS o-rings, and the special-shaped oil feed o-rings. You'll also want to anneal or replace the special-sized copper crush washers that seal the oil-feed to the head (the outer two studs on #4).
  3. sybe
    sybe Active Member
    NYC - Brooklyn
    I already did all that. My funds are low so my friend offered it for free to see if it will work. The only difference between the xj650 and xj750 part number are the first 3 numbers.
    Hoping it will work.
  4. Polock
    those ain't cheap, it's worth it to lay it on there and look see
  5. chacal
    The XJ750 engines have a larger bore, would not recommend............
    Jetfixer and k-moe like this.
  6. k-moe
    I knew there was some other difference that I was forgetting. Thanks.
    Jetfixer likes this.
  7. k-moe
    Those are important numbers. Check out Chacal's post. It won't work.
  8. MiGhost
    MiGhost Well-Known Member
    As chacal mentioned the difference in bore size will leave a gap between the head, and cylinder all the way around the bore.
    The correct head gasket is not that expensive.
    ~Ghost
  9. sybe
    sybe Active Member
    NYC - Brooklyn
