xj750 mid max been sitting up and abused way too long
Discussion in 'XJ Technical Chat' started by nooneactually, Mar 25, 2014.
  1. nooneactually
    nooneactually New Member
    Plano, TX
    I just got a hold of a early 80's model xj750 mid max with the yics motor.
    This little gem has been sitting up for quite some time and just from the looks of this beaut shes been abused pretty badly. I can get her to start up pretty easily, and she idles and revs up okay enough (though once i rev her up and release the throttle, the rpms linger then slowly descend, not immediatly like my previous girls)
    another odd problem is while riding her down the road, i have good power off the line, but once i get into the higher rpms in second gear and above i loose a lot of power and i begin getting a lot of sputtering sounds, almost like the bike is only runnin on two cylinders.
    im curious the check list and order i should start checking, cleaning, and adjusting, I'd like to go to pod filters to open up the inside of the frame, but ive read a few different threads saying that they were difficult, but can find no explenation as to why. I also read on another thread that i cant just go adjusting the carbs for pods, that i needed to check other things in certain order to ensure its in tip top shape before going to pods.
    Ive had a couple bikes previously to my mid max, but none that needed so much love. Im really looking forward to the challange, but im trying to find a good starting point. hopefuly some of you can help me.
  2. hogfiddles
    You need to address:
    Valve shim clearances
    Carbs thoroughly cleaned and rebuilt
    sync and colortune
    check all wires, connections, etc.... I'd recommend upgrading the fusebox
    total brake system clean/rebuild/replace shoes and pads
    replace tires
    thoroughly clean the tank
    The symptoms you give are normal for the condition, but when you get it all cleaned and back in spec, you're going to be surprised with what these can do.
    Now, make sure to put the year of your bike in your signature. I assume that when you say mid max, you mean a xj750 Midnight Maxim. That's a pretty nice find.............
    Glad you found us! You'll never leave.............
    Welcome to the Hotel XJ-fornia............................
    dave
  3. adrian1
    adrian1 Active Member
    "They stab it with their steely knives but they just can't kill the beast"
  4. BruceB
    BruceB Active Member
    Isle of 8 Flags, Florida
    "We are all just prisoners here, of our own device"
  5. adrian1
    Touche!
  6. wscraig76
    wscraig76 Member
    Southern Illinois
    First bike I ever owned was found in a dumpster too.
    Turned a wrench, spent a few dollars.
    Rode it for 3 more years before I left it NEXT TO the dumpster 1 year after that. It was the elite 50 in my signature.
  7. wscraig76
    wscraig76 Member
    Southern Illinois
  8. bigfitz52
    Pod filters and CV carbs have issues because CV means "constant velocity" and pods don't provide that.
    Like HogFiddles said, valves, carbs, brakes. Then worry about mods; if you start cutting into it before you get it running you might not.
  9. nooneactually
    Plano, TX
    Well, i pulled the carbs out. Im in the process of cleaning them really throroughly. Is there a thread or a good place to look to get help with the shims? this is the first time ive had to go this deep in a bike and its gonna be a lot of learning. lol.
  10. biggs500
    biggs500 Active Member
    Sherwood WI
    This little gem of a walk through will help with the valves.
    Try reading In the Church of Clean for tips on cleaning the carbs.
    Explore the site. It's a treasure trove of information.
  11. biggs500
    Sherwood WI
    Another quick tip: Shortcuts make for short rides. :) Take your time and do the job right. You'll be glad you did.
  12. nooneactually
    Plano, TX
    YET ANOTHER QUESTION. Where can I find the stock specs for my bike? Stock jets, shim clearence, etc?
  13. midnightmoose
    midnightmoose Member
    York, PA
    In the service manual! If you don't have one yet...get one!
    You're going to need it!
  14. biggs500
    Sherwood WI
    Click here and scroll about 1/5 of the way down for information on jets.
    Valve clearances are .11~.15mm for the intake and .16~.2mm for the exhaust.
    Click on the XJ Forever link on the top right of every page and you'll be able to find almost any part you'll need.
  15. nooneactually
    Plano, TX
    Carbs are clean and bike is running much better than before. Wayyyy better. Now I'm having a problem with idle. Idles at 4 grand. Idle adjustment screw does nothing. Choke does nothing. Very frustrating to say the least.
  16. hogfiddles
    I wonder if :
    -one of more Carb butterfly springs are too tight
    -have you running-synced the Carbs
    -have you checked for vacuum leaks
    Dave
  17. biggs500
    Sherwood WI
    You most certainly have a vacuum leak. If I were to guess I would say the throttle shaft seals.
    Here's a walk through. You have to keep in mind you're dealing with 30 year old stuff here and rubber doesn't stay real soft and supple over those time frames. Unfortunately you'll have to pull and split the rack, but keep in mind, subsequent times become easier. I found this out the hard way too. :(
  18. nooneactually
    Plano, TX
    I actually fixed both of the previous issues! Haha. Bikes running even better. I do now need to do a running sync. With the yiks motor, what's the best way to do this at home? I've seen many videos about using a little home made set up with a couple vacuum lines and some liquid etc etc. y'all likely know about it. Is this a functional system for the yiks? Better ideas?
  19. hogfiddles
    The BEST way it to order yourself a carbtune unit. They run a bit over $100 bucks , but you'll never have trouble with it, you can tune everyone's bike near you, and you can take it to carb clinics with you...... Everyone will think you're a god. :)
    Dave
  20. nooneactually
    Plano, TX
    dang. i was hoping to get it tuned up tonight. will that system work with the whole yics synchronization bar thing?
  21. k-moe
  22. hogfiddles
    I have the Morgan CarbTune Pro, I use it a lot and LOVE IT. I also have a YICS tool and ever use it. I'll start the next round of volleys by saying that in my opinion you don't really need to use it.
    Dave
  23. nooneactually
    Plano, TX
    I made a two cylinder balancing deal. How should I pair the carbs up. 1/3 then 2/4 then balance the pairs?
    _________________
    Current Scooter: 1983 Yamaha 750cc Midnight Maxim (rat bike project)
    Past Scooter:
    1991 Suzuki 750cc Intruder (bobber project)
  24. tcoop
    tcoop Active Member
    South Weber, Utah
    1/2 then 3/4 the 2/3
  25. nooneactually
    Plano, TX
    im looking to buy new clutch levers and master cylander assembly. Ive found them at a decent price on ebay and things, but i wanna make sure i get parts thatll definitely work. What specs do i need to know?
  26. nooneactually
    Plano, TX
    and how do i buy things from the xj4ever link? or is it to just give me part numbers
  27. k-moe
    You have to ithe PM or e-mail in your order.
    The bottom of the first post in section A:
    As usual, if you have any questions, please write to us via a PM (Private Message) through this website, e-mail us via the "email" button on the bottom of this post, or e-mail us directly at:
    info @ xj4ever.com
    NOTE: our e-mail address does NOT have spaces before or after the "@" symbol........the posting system on this website automatically adds blank spaces before and after that symbol as an anti-spam feature! Make sure you eliminate those blank spaces when sending us an e-mail! Our e-mail address does NOT have any blank spaces in it!!
    PLEASE!: on each and every correspondence with us, please tell us what YEAR and MODEL bike you have (example: 1982 XJ650 Maxim) and what your NAME (first name, at least!) is......that information really makes life a bit easier for us, and insures a more timely and ACCURATE response from us back to you!
    Paypal accepted. Worldwide shipping available. Shipping prices and insurance costs are NOT included in the prices of items unless specifically listed. Prices and availability are subject to change. Please write with your list of parts needs and I will be glad to quote your shipping costs to you.
    We appreciate all of your business, and look forward from hearing from you soon.
