xj750 middle gear case oil level maintaining plug?
Discussion in 'XJ Technical Chat' started by MinutemanMedic, Mar 27, 2023.
  1. MinutemanMedic
    MinutemanMedic New Member
    Kansas
    Hello, all.
    Was replacing the left crank case cover gasket on my 83 750 Seca and noticed this plug was damaged - a portion had broken off and was sitting in the lower half of the cover. I can't seem to locate a replacement, d0es anyone have any idea where I can find one or if I'm even calling it the right part? I found the phrasing in the attached screenshot from https://www.xjcd.org/book/export/html/654.
    **EDIT**
    Upon a little more review I don't actually think the plug was the issue - it actually looks perfectly fine after cleaning off a bit. The piece I located is in the images attached and I'm at a loss as to what it could have broken off from. Thoughts?
    TIA
  2. Franz
    Welcome to the forum. That plug keeps the oil in the bevel gears for the driveshaft. @chacal aka Len the site vendor might have them you can contact email him on info@xj4ever.com
  3. Franz
    That is a piece of the alternator/starter chain guide. It will affect gear changing and you need to split the crankcase to replace it.
    MinutemanMedic likes this.
  4. Franz
  5. Dan Gardner
    Minneapolis, MN
    Yes, looks like a hunk of chain guide
  6. MinutemanMedic
    Kansas
    Franz likes this.
