XJ750 RK Seca Speedo assembly
Discussion in 'For Sale, Trade/Swap, Wanted' started by bstig60, Jul 5, 2016.
  1. bstig60
    bstig60 Member
    Sharpes, Florida
    Wanted, good working condition Speedometer assembly for 1983 Seca 750 RK. My speedo is making a lot of noise......
    Have yuo opened it up and lubed/cleaned the speedometer? How about he cable, has it been lubed recently?
  3. bstig60
    bstig60 Member
    Sharpes, Florida
    No, I haven't opened it up, but I did check the cable and it is OK and well lubed. I will open it up and check it, but it is likely from the loud whine that lubing will not last long. Is there a thread here with a procedure to service it?
  4. hogfiddles
    The 750 Seca unit is very accessible and straight-forward to open up.
  5. k-moe
    And lubricating the speedometer workings does fix the issue. I did mine four(?) years ago, and it hasn't whined since.
    There is a thread on the DYI section of this forum. It does not cover dissasembling your gauge cluster, but the speedometer is essentially the same.
  6. bstig60
    bstig60 Member
    Sharpes, Florida
    OK, I will try lubing the unit when I get down to my son's place next week end. My XJ has the touring package on it, so it is not as easy to get at to remove it. I may have to remove the fairing. What kind of lubricant do you recommend??
    Bill
  7. k-moe
