XJ750 Starter Clutch condition?
Discussion in 'XJ Technical Chat' started by Dantoys, Jul 10, 2018.
  1. Dantoys
    Dantoys New Member
    Williamsport, PA
    First, Thanks everyone for the great Forum and great source of info.
    I have a '82XJ 750 . I have removed my Starter Clutch to fix a starting problem.
    Below are some pictures, there is a crack in the Starter Clutch Assembly. it is clean enough that I am questioning if it is intentional. Can anyone let me know if this is normal. Thank-you.
    That is not normal. You have a cracked part. Start a conversation with Chacal for a replacement.
  3. Dantoys
    Dantoys New Member
    Williamsport, PA
    Thanks for the quick reply, I found a new part.
  4. Jetfixer
    That is one symptom of starter slippage the springs and roller loose tension and slip. Your is the extreme end :(.
