Xj750rh seca flasher signal disassembly
Discussion in 'XJ Technical Chat' started by Aurel, Aug 15, 2024.
  1. Aurel
    Aurel Member
    Texas
    Hello, I'm repainting the whole bike piece by piece and I would like to powder coat the chrome piece of the signal, (PO spray painted them black). They're in pretty bad condition and I don't want to damage them more by guessing my way to dismantle them, if anyone know how it can be done? 20240815_032154.jpg
    You can't. The rubber is heat-molded to the steel.
    You can wire brush the paint off and electroplate the visible metal in nickel at home though.
  3. Aurel
    Aurel Member
    Texas
    I didn't see your message before doing it, I managed to take it apart, I probably broke the heat molded part :( 20240818_000744.jpg . Went from the bulb housing to the chrome piece (it has threads inside). I've got some more restauration to do, I think the rubber piece connecting to the threaded stud was heat molded on it, ill find a solution but I think it will turn out ok!
