Xj900 1984 cam chain wear pad replacement
Discussion in 'XJ DIY How-To Instructions' started by jim kibblewhite, Oct 19, 2019.
  1. jim kibblewhite
    jim kibblewhite New Member
    Caulfield Australia
    Hello all, I’ve bought a old 100,000 km xj900.
    It needs a replacement cam chain and wear pads.
    Can this be done in frame?
    Or do I need to take the engine out of the bike.
    I’m a rookie on a bike.
    Thank you for any thoughts.
  2. Franz
    Welcome to the forum. You don't need to remove the engine from the frame. But l am not sure if you need to remove the cylinders to get the cam chain guide out if you are replacing that on the tensioner side. The other guide will come out. Other forum members will advise you further.
  3. k-moe
    Both cam chain guides can be removed with the engine in-frame and removing the valve cover. The rear guide is held by a locking bolt on the rear of the upper engine case, and you will need to remove the cam chain tensioner as well (get a new gasket for it).
    I strongly suggest that you purchase a shop manual for your bike (either the Yamaha manual or the Haynes). Both are availble from their respective publishers online.
    Dave in Ireland and Franz like this.
  4. jim kibblewhite
    Caulfield Australia
    K- moe,
    Thanks for for the heads up in the cam chain guides.
    Yep just got an original manual. Not that informative though.
    I’ll give it a gone try weekend.
    Will replace the cam chain at the same time.
    Thank you all.
  5. tjantunen
    tjantunen New Member
    Finland
    Old thread but I am also interested how the front chain guide is possible to remove engine in place?
