Wanted Xj900 Seca Roller
Discussion in 'For Sale, Trade/Swap, Wanted' started by Xjbyoung, Jul 26, 2025.
  1. Xjbyoung
    Xjbyoung New Member
    TN
    Looking for 900 seca does not have to run
    Looking for complete front end and rear swing arm with brakes.
    I'm located in TN
  2. hogfiddles
    Are you looking for a complete bike?
    Or just parts?Are you restoring one, or looking for one TO restore? If so, how far are you willing to travel? I MIGHT have one or two………
  3. Xjbyoung
    Xjbyoung New Member
    TN
    Hi Dave
    I'm wanting a 900 front end and a 900 rear swing arm to swap to my 82 xj650 turbo.
    That would give the bike the adequate braking it should have had from the factory.
    I could also make a FJ600 front end work.
  4. Xjbyoung
    Xjbyoung New Member
    TN
    also I'm in TN so shipping would be needed from NY
  5. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    Fyi: xj900 swingarm is wider than the xj750 swingarm by a bit, not a lot but enough to have to alter the frame. Probably applies to the 650 also.
    I converted 2 750s to the 900 swingarm and rear wheel for the disc and there was a bit of pain and dual adjusting stubs in my case at any rate.
  6. Xjbyoung
    Xjbyoung New Member
    TN
    Dave,
    Do you know if the Radian forks are 36mm Diameter. They look the same as the FJ600 and 900 forks. I know the 900 are 37mm
  7. Simmy
    Radian forks are 36 mm.
    I installed them on my sidecar
  8. Simmy
    I have FZ600 forks on my Turbo, this gives you the variable dampers.
    note I have switched both bikes to run 16" wheels
