XJ900 TCI
Discussion in 'XJ Technical Chat' started by wizard, Jun 29, 2010.
  1. wizard
    Hi guys, I have been sent a used TCI for my '83 XJ900, but it is different from the original, can anyone tell me if this will work, I won't plug it in 'till I know.
    Original # TDI14-37....58L-10
    Replacement. TDI14-02....4H7-10
    Original has 4 pins & 6 pins
    Replacement has the same size connectors, one large & one small, but the large one only has 4 pins.
    Thanks Wiz.....
  2. chacal
    That's for a 1980-81 XJ650 model (non-YICS)......lacking two pins since there was no sidestand safety relay used with those bikes........will probably "work" (as in, "allow the engine to run"), but, not run real well......
  3. wizard
    These 900s over here didn't have the sidestand cut off switch, so it might be OK, I will check again with the supplier (an xj bikes member) before I try it.
    Thanks Len.
  4. adrian1
    adrian1 Active Member
    Not so Wizard.....mine has a side stand cut out
  5. chacal
    According to parts books, only the 900RK and 900F models have the sidestand switches..............which is really odd, but that's what the Parts Bibles say........
  6. wizard
    adrian, I have an '83 & an '85, both without, you have a later model, obviously my knowledge doesn't extend to the later bikes, thanks for the input. Wiz...
  7. railtrolley
    railtrolley Member
    Melbourne, Australia
    Just to add further confusion, mine does not have a side stand switch. It does have a clutch switch, so I have to pull in the clutch lever every time I start it.
  8. discostu_001
    discostu_001 New Member
    Hi mate, did you end up having success with this?
