Xj900f what am I doing wrong
Discussion in 'XJ Technical Chat' started by Russtic, Apr 4, 2025.
  1. Russtic
    Russtic Member
    Uk
    I have rebuilt my callipers replacing all of the rubber. I can’t see any leaks. However despite two hours of using vacuum pump I cannot get an any resistance on the brake and still see bubbles.
    I have tightened everything.
    any ideas
  2. Russtic
    Russtic Member
    Uk
    Apologies I have duplicated post and can’t see how to delete
  3. Fuller56
    Fuller56 Well-Known Member
    What to do to start depends on which XJ you have. Your avatar looks like a 750 Seca which has the strange remote master cylinder down in the headlight area. My advice is to start the initial bleeding attempt by pumping the brake lever and holding it while just cracking the bolt at the master cylinder a couple of times. In a new, dry system that will often get the bleeding process started then you can move on to finishing out the bleeding more easily. I am not sure how easy that will be on you bike as I have avoided those master cylinders. Good luck!
    Russtic and Franz like this.
  4. Timbox
    Timbox Well-Known Member
    If you have bubbles, and you have known leak of fluid, you are doing it right. It might take a long time to get all the bubbles out of the line. It can take a while. I take a wrench of screwdriver and tap the line as I pump the lever. It seems to help move the air in the line and help out a little.
    Show us a pic of the MC you are having issues with.
  5. Russtic
    Russtic Member
    Uk
    It is my xj900f. Which has standard handlebar mc. I tried bleeding for about 2 hours and still had no resistance. I think air is getting in the bleed scre so am going to try some grease.
  6. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    The bleeder threads are not tight fitting until tightened. Just crack it open when bleeding or air can get through the threads and make bubbles.
  7. Timbox
    Bleed screw should be tight until the system has pressure on it. Using a clamp to hold the leaver in place works okay if you can't hold the lever and crack the bleeder fitting at the same time. Just a short open and then close it again before you let pressure off the lever.
    You don't have any fluid coming out of the bleeder screw area, puck on the caliber or dripping from under the MC? You might have to watch a few vids on youtube to get the hand of of it. That or you might have to reverse bleed the system to get it to work.
  8. Huntchuks
    East Rochester, NY
  9. Robert Strumbell
    Robert Strumbell Member
    United States duluth mn
    You need to start at M cylinder. If its banjo fitting, put sleeve on bolt to plug, if its pipe thread, find threaded plug or plug hose.
