XS400 Maxim Wiring Harness
Discussion in 'Other Motorcycles' started by vincentmoy, Aug 15, 2009.
  1. vincentmoy
    vincentmoy Member
    Anchorage, Alaska
    So I may need to replace the wiring harness on my 82 400 Maxim and I have no clue what to do.
    The reason behind is that my oil pressure light would not comes on when it should. I went through 3 different switches and still is not working (worked for 2 days and then not working again). Some say it's the wiring but when I gnd the wire where it connects to the switch the light will goes on.
    That's what I need to check all the wiring and probably replace the harness.
    Anyone done that before?
    Thanks!
  2. dwcopple
    dwcopple Active Member
    bay city, michigan
    that is a ton of work for an idiot light. Do you really need that light to work that badly? I'm just saying...
  3. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    I'd be checking those connections in the headlight bucket first.
  4. vincentmoy
    vincentmoy Member
    Anchorage, Alaska
    I checked em and it's good
