XV750/1100 mongrel
Discussion in 'Other Motorcycles' started by faffi, May 16, 2023.
  1. faffi
    faffi Active Member
    Norway
    Hi!
    I presume this very nice place on the World Wide Web have become enriched with many new members since my last post. No need to tire you with my absence, but it has all to do with life, and nothing to do with this site or its members.
    Since I was last here, I have spent every moment available to completely strip and redo my Mongrel; a 1982 XV750 Virago fitted with a 1990 XV1100 Virago engine. I performed a less involved resto-mod back in 2016, then rode it through the 2017/18 winter, with lots of salt on the roads - and never washed it. Until this fall. The result was that rust had eaten into just about every part of the bike, from stands up through the exhaust and frame and into the fenders.
    As it was, looking surprisingly good - after its first clean in 6 years - consider the amount of corrosion it suffered
    This detail picture of the frame is pretty representative for the state of the metalwork on the bike
    I finished it up today. This is how it looks now, sorry about the messy background
    For those with nothing to do, I will include a list below the pictures of what I have done to get to this stage. At least what I can remember of it - there have been so many minor things it could fill a book.
    Fuel tank from the top, my own design and paint. I won't take offence if you do not like it, as I know it is not run of the mill
    Showing more of my messy shop
    Even more clutter
    New self-made wiring harness hooked up
    Testing the wiring/function before taping up and running it inside the frame, note new "brain"
    Oxford heated grips
    One-off bracket holds non-stock Mosfet R/R
    SUMMARY
    Stripped bike completely other than engine, which remained mostly intact, but lifted out of the frame.
    Stripped frame and stands and fork lowers and grab rail and rear fender and triple tree and front engine mount and swingarm of paint and rust/corrosion
    Painted frame and stands black
    Painted lower triple tree silver
    Lightly polished fork lowers and upper triple tree
    Polished very dirty and rusty front header pipe and "new" second hand mufflers
    Lightly cleaned and polished wheel rims
    Overhauled the brake system with new pistons and seals
    Fitted brake disc off a Seca 750, saving about 2 pounds of unsprung weight
    Fitted front fender off a Seca 750, requiring mods of the brake line bracket
    Fixed inaccurate rev counter by replacing seven capacitors
    Drew up totally new wiring harness and built it, omitting all but one relay (for starter) and all safety gadgets
    Ordered and fitted new TCI (brain) made to order in the Netherlands
    No room for the TCI on the Gen I frame, so I had to make place through an inverted box inside the pillion portion of the seat
    Fitted new bearing spacer and end seals for the swingarm
    Seat had already been fully reshaped by me in 2016, but made a new cover for it
    Fitted new tires, 130/80-18 rear (Seca wheel) and 100/90-19 front
    Fitted handlebars off my in parts NT650V Deauville
    Fitted two-way throttle so I could use both cables (open / shut) like you find on the later carbs
    Fitted Oxford heated grips, with mount for control pod requiring mods to fit on the right since the old clutch lever holder is held with a single bolt clamp
    Cleaned, stripped and zinc-plated lots of bolts and bracket
    Stripped and ultra-sonically cleaned the carbs, zinc plated all steel parts
    Made a new front for the RHS sidecover, as I had earlier cut that off to fit a number plate. Used bits off the Deauville fairing, reshaping it and welding it in place with soldering iron
    Removed, stripped, cleaned, fixed and remounted the starter motor - much more pain that it should have been due to the ¤&¤%#& starter system design
    Made a new tail-light fit the fender
    Made a bracket for the R/R
    Fitted new YSS shock absorber
    Modified fork damper rods and fitted YSS emulator valves
    Painted tank, fenders, head light and sidecovers and covered with 2K clear - orange match my helmet that I painted a couple of years back
    Of course, new oils and filter and battery and lots other small stuff you tend to forget about
    Engine fired instantly after all this, which was a relief - I was afraid I had messed up the starter system and/or the wiring, but all is good. So far, at least. Tomorrow is our "4th of July", but I hope to take it for its inaugural pre-resto ride on Thursday.
