XV750 Off Roader - Pic Heavy
Discussion in 'Other Motorcycles' started by Alive, Aug 9, 2009.
  1. Alive
    Alive Active Member
    Queensland, Australia
    Not really an "Other Motorcycle" but at least it's powered by one :)
    Then I scored a new motor.... 33k ml but siezed
    And now after a wee bit of work...
    Had some wielding done on the frame yesterday so I need to do some grinding, prep & painting before I put the motor back in.
  2. Alive
    Alive Active Member
    Some more pics....
    How it's sitting right now:
  3. Alive
    Alive Active Member
    The carb transformation...
  4. That_Guy
    That_Guy Member
    Pennsauken, NJ
    wow man i am really impresseed with that motor transformation
  5. Alive
    Alive Active Member
    Only took a couple of months to strip 2 engines (top end only), clean, and rebuild. I went through a few litres of degreaser, alloy cleaner and the bits n pieces spent some time in my sand blaster. Finished off with a coat of barrel paint from the local bike shop.
    I'm shocked at how good it came up :)
  6. That_Guy
    That_Guy Member
    Pennsauken, NJ
    ya it really came out great good work
  7. Roys85XJ700
    Roys85XJ700 New Member
    Charlotte, Michigan
    WHat media did you use? Motor and carbs look great. I have to do mine is why I'm asking.
  8. Alive
    Alive Active Member
    I just used the sand that I got from the local auto shop.
    I always do a test piece first just to make sure.
    the only thing that removed the oxidization from the alloy (it was really bad) was sand blasting... Even the wire brush wasn't as good.
    I find the blaster finish to be far more consistent.
    I did give it a soak in alloy cleaner (acid based) after the blast just to make sure the surface was clean before painting.
  9. Alive
    Alive Active Member
    Oh something else I forgot to mention... It cost me $100NZD to buy... I paid $250 for the donor bike and an XZ400. Got $55 for the Virago leftovers and $18 for the 400. Gasket set cost me $120, set of XV100 carbs was $40, barrel paint was $17 and exhaust paint cost $21
    So all up it owes me $475NZD :lol:
  10. lowlifexj
    lowlifexj Member
    Grand Haven,MI
    That thing looks like it would be a blast!!!!!!!!!!!!!
  11. Alive
    Alive Active Member
    It's definitely stupid grin material...
    I got 1 good run before seizing the old motor and ripped up a piece of land across from home... Donuts galore lol
  12. Alive
    Alive Active Member
    I've been plugging away at it today....
    Gave the engine another light coat of paint, painted the 2nd header (did the other last week and got the first coat of blackl on the frame... 2nd coat tomorrow.
  13. Alive
    Alive Active Member
    Back in black.... Well black and silver :)
  14. Mad_Bohemian
    Mad_Bohemian Active Member
    Ravenna MI
    Pretty cool!! You DEFINITELY need to post some vids when you get it up and running!!
  15. schooter
    ya. thats going to rip. also, i would reccomment investing in some atv tires and rims, those golf cart tires do it no justice. want the best setup? in the back put on kenda bearclaw tires, and in the front, holeshots, you'll go through anything
  16. Alive
    Alive Active Member
    Mad.... You read my mind lol
    Scooter... Thanks for that. I've been leaving the tyres and rims to last... Trying to keep the budget to a shoe string so probably won't be able to put those on.
    This is probably only going to get used a few times by me.... Need the space back in my garage. Just bought a damaged XJR400 for $100NZD so more space in garage is good :)
  17. Alive
    Alive Active Member
    Oh and FYI...
    Engine is painted with PJ1 Cylinder paint - Silver I think
    Headers were done with PJ1 Exhaust paint - Black
    & the frame was done in an epoxy black... 4ltrs of the stuff.... Overkill :)
    I still have to mount the tank... Alloy coffin shaped tank off an XS1100 that I painted black.
  18. turtlemann14
    turtlemann14 Member
    i think he is going to need more suspension (but i could be wrong)
    vids are a must
  19. Alive
    Alive Active Member
    Thanks schoot.... your suggestion led to this....
  20. Alive
    Alive Active Member
    Extra points to anyone who can name the 4 bikes in that photo :)
  21. Polock
    i'd like to see a fan on at least the back cylinder, that firewall will restrict some air flow on it and it's just not going to have the same kind of air flow in general that a bike gets going down the road
    seat belt ?
  22. schooter
    awww ya alive!
  23. Alive
    Alive Active Member
    That's a good point Polock... Can't say i'd thought of that.... I'll have to get back to you on that one.
    Yes has twin seat belts.... Got the lugs weilded on recently :)
  24. Alive
    Alive Active Member
    Couple more hurdles, a little progress.... Gutted that the new rims don't fit :cry:
    This gives you an idea what they would look like...
  25. schooter
    oh man, thats too bad.... that looks sweet. Nice job tho man.
    It still would be possible to machine adapters...
  26. Cooter
    Cooter Member
    Chi-Caw-Go
    You could also redrill the wheels. I had to do that to wheels I ordered for my Raptor. They arrived just a day before my trip to the north wood, and I had no choice, unless I ran the nearly bald tires that came with the quad. And it was raining all weekend. As long as the center register matches up, and the centers of the wheels are flat, go for it!
    ~ edit~ Just looked at the pix of the new wheels. No easy way to drill them. Bummer.
  27. Alive
    Alive Active Member
    If I re-drill the rims they'll become instantly worthless.... and you're right, they cant be slotted or drilled anyway.
    I've got my hands on some brand new drum brake setups and a quad front end that the new rims fit on to so hopefully I can get them to fit the current setup.
    That and I have to pull the cams out and swap them around (swear loudly).
    Also still have to get another coby mounted to the left pipe, fit the seat belts, mount the fuel tank...
    So close yet so far away... sigh
  28. Alive
    Alive Active Member
    Ok so I finally gave it another crack over the last few days....
    Gave up on trying to fit the off road tyres for now so I could focus on making it run... And last night it did, rough but it ran
  29. David3aces
    David3aces Member
    St. Pete Fl.
    Hope that starter bendix works well.
    Nice project!
  30. Alive
    Alive Active Member
    Na... Starter is in need of another overhaul
  31. Alive
    Alive Active Member
  32. gunnabuild1
    gunnabuild1 Member
    That lump in the front looks great, bet you it sounds lumpy too.
    That lawnmower tank wouldn't keep you going for long would it?
  33. Alive
    Alive Active Member
    Sounds down right deafening lol.... No, get about 10 minutes per tank
  34. mlew
    mlew Well-Known Member
    Apex, NC
    when can we see some video of you tearing up the pavement?
  35. TIMEtoRIDE
    The Virago had 4.13:1 gears. What gears are in the axle ??
    Will it wheelie ??
  36. Dave_89_VMAX
    Dave_89_VMAX Member
    Charlotte, NC
    YOU ARE A SICK MAN... and I like that!!! sweet toy. I had a passing thought of doing this with a wrecked kz 550 (thats what happened to the past one ) but never got it off the napkin. Great job and I too look forward to the video!
  37. Alive
    Alive Active Member
    No wheelies ... Too much weight in the front... Wheel spins in every gear though lol
    I got a 5 minute run before I lost the clutch yesterday and didn't pull my camera out...
    Will definately video the next run :)
  38. Alive
    Alive Active Member
    [video=425,344]http://www.youtube.com/watch?v=SU-wJnwmOQk[/video]
  39. Alive
    Alive Active Member
  40. Alive
    Alive Active Member
  41. dwcopple
    dwcopple Active Member
    bay city, michigan
    that seems much slower than I had anticipated. :(
  42. FLASH4
    FLASH4 Member
    On the back wheel, in AUSTRALIA!
    Sounds like you have a fuel supply issue? are you getting enough flow to the carbs from that little tank and (i suppose) little fuel tap? Looks like great fun, and definetly a different to the normal m/b cart setups. Build it yourself?
  43. Alive
    Alive Active Member
    Yes running like a dog.... I'm pulling the carbs down to check if i pumped dirt in to them from a dirty tank... It definately needs a fuel pump setup
  44. Alive
    Alive Active Member
    Gave the carbs a good clean... they had some crap in them but didn't make any difference to the running.
    Going to go back over the cam alignment and tappets before putting my carb sync on it and setting the mixture.
    I'm hoping this will get it running better.
    I'm also suspicious that having the small header type tank is possibly adding to the starving fuel scenario so I'll take that out of the equation too.
    If only I had more garage time and motivation lol
  45. schooter
    sweet lordie, very nice, some type of fuel pump may help, you can just wire it to its own toggle and remember to turn it on and shut it off every time, a better tank may help, but I was looking over the frame, and theres no safe and ideal place to put that tank.., but very nice, it would be awesome if those kenda's worked on that cart..
  46. TIMEtoRIDE
    Alive- - '80's Subaru's have the pump you need, under the hood.
    That's a wicked kart, my friend !!
