Yamaha emblem on gastank. want off.
Discussion in 'XJ Modifications' started by essdot, Sep 18, 2008.
  1. essdot
    essdot New Member
    I want to take off the yamaha emblem on the gas tank of my 82 550. Im going to paint it soon, but I want to keep riding it until the time, if I was to take the screws out that hold the emblem on, is there a nut in the tank, or is it a threaded bracket? I just want to ensure that I won't $^%& up. Thanx again fellas.
  2. stereomind
    stereomind Active Member
    Tulsa, OK
    the nuts are part of a bracket, which is welded to the tank. some body filler would make the whole thing disappear...
  3. Ease
    Ease Member
    NL, Canada
    The screw doesn't go through into the tank, there'll be an indent with a nut tacked to it.
  4. bigfitz52
    I'll bet you could find someone with a "filled in" tank to trade with. The emblems are attached to a double-ended bracket with screw holes tapped in each end that is "countersunk" into an appropriately shaped depression in the tank. Why not repaint and then install brand-new emblems?
