Yamaha fairing parts?
Discussion in 'XJ Technical Chat' started by maz43, Jul 8, 2008.
  1. maz43
    maz43 Member
    Detroit area
    I am missing a hatch for the left side compartment on the fairing.
    The dealer says it isn't stock but an option and has no idea on parts for it.
    The faceplate on it says Yamaha 24M-28300-50.
    Any here have any ideas how to find the missing part?
  2. Marine36
    Marine36 Member
    Gerald, MO
    Is the fairing a yamaha fairing. Can you post a pick of the cover you have?
    I have a yamaha fairing with good lids for compartments and good windshield everything else is junk. I think I even have the key for the covers.
  3. conn110
    conn110 Member
    I did a quick bit of research on the subject of your fairing. Apparently, Yamaha was re-labeling Windjammer fairings and painting them to match the bike. So , even though it has a Yamaha part number, you may be able to pick up Windjammer parts for your fairing at www.craigvetter.com . He invented the Windjammer and now sells replacement parts for them. You just need to figure out which "Windjammer" you have. They might be able to help with I.D.ing it.
    Also, Yamaha re-labeled fairings from a company called Pacifico as well. You might try googling them to see what you find.
  4. grimreaper169
    grimreaper169 Member
    Mims,Fl.
    when you say junk what does that mean I'm looking for a fairing for a 82 750 xj I can rebuild it I can make it better than it was..no wait that was a tv show. Can you shoot me a pic of said fairing.Also do you have the mounting hardware?
  5. maz43
    maz43 Member
    Detroit area
    The fairing is a Yamaha- heres a crappy pic. Looks like i need a new camera too. If it matches your "junk" fairing I could sure use that lid......
  6. grimreaper169
    Mims,Fl.
    What do you say Marine36??????????????/
  7. grimreaper169
    Mims,Fl.
  8. Marine36
    Marine36 Member
    Gerald, MO
    sorry y'all I was sleeping and working. Lids on my fairing do not match yours.
    attached is a picture.
  9. Marine36
    Marine36 Member
    Gerald, MO
    I have part of the mount. The rest was cut off by PO to mount turn signals without fairing. Also only have one side panel not pictured.
  10. grimreaper169
    Mims,Fl.
    damit man I have a rectangle head light ok thanks tho I will keep looking
  11. beerman
    beerman New Member
    I have the same Fairing that came with an XJ750J Maxim I recently aquired. I am missing a cover also, but that's because it looks like there used to be a stereo there. Anyway, can you send me a picture of the mount for that Fairing. This one didn't come with one unless it just mounts without one. I'd appreciate it if you could help me out.
