Yamaha Oil Cooler Bolt
Discussion in 'XJ Technical Chat' started by Franz, Feb 6, 2020.
  1. Franz
    Hi Guys
    Do you know if Yamaha used the same thread on the oil cooler through bolt to the crankcase on the XJ series and Diversion engines? I am wondering if the one from the 900 Diversion pictured is an M20 with thread pitch of 1.5?
  2. Franz
    Any answers guys on my question?
  3. dkavanagh
    Rochester, NY
    Probably not much help, but I'd start with the parts catalog and compare oil cooler bits from the different bikes. If that threaded part happened to have the same part #, that's a good bet it's the same.
  4. Franz
    Yes thanks l think the chances are the threads could be the same but l will double check.
  5. XJ550H
    yamaha would not change a part if it was not need to change but I do not have access to part numbers.
    yambits may have the part number for the diversion 900
    83 900 part number click on part number and you will see all the bikes the union bolt fits for US bikes
    BOLT, UNION Not Available
    90401-20089-00
  6. XJ550H
  7. Franz
  8. Franz
    Plate adaptor for 900f is 5N1134610100 from CMSNL
    Diversion is 4KM-13461-00-00. They look identical but have different part numbers unfortunately.
  9. XJ550H
    sometimes a new part number is the same thing just an updated part number. I see it alot with xj parts on partzilla where they list both part numbers with the old part number lined out.
  10. Franz
    I can get parts off E Bay so I think I will buy them and see if I can convert my bike to the spin on filter. That is good about the different part numbers, being the same part. Yamaha probably used the same parts on all the XJ's. I read a write up on the forum and here is one I read on other Yamaha machines.
    http://www.xs400.com/threads/spin-on-oil-filter-oil-cooler-sohc.15184/
  11. Timbox
    Timbox Well-Known Member
    If you are going to keep the motorcycle, those spin on filters are very nice. Once you get used to the OEM type it is not too bad. You can find OEM from $4 and up, but you are correct, that spin on filter is very nice.
    Franz likes this.
  12. Franz
    Yes it looks good and is easier to change and their is no bolt head to get damaged.
  13. XJ550H
    also good if doing a long road trip makes changing oil and filter on the road
    Franz likes this.
  14. Dave in Ireland
    Ireland
    Here's mine
    https://www.xjbikes.com/forums/threads/spin-on-oil-filter-for-xj900f.124259/#post-624325
    The plate was from a Divvy 600 iirc, and I had to shorten the central bolt by 3mm as I mention there, to securely tighten down onto the cooler adapter and squish the bit O-rings behind it. I don't recall whether I used the original central bolt or got one from a Divvy 900.
    Thinking back on it - my original cooler plate is slightly different to a later one, hence the need to alter the spacing. Same diameter, different thickness. From what I recall looking at all the XJ cooler adapters I could find, there are some differences, but they all fit in a mix and match way, but some need slightly adapted, like mine. As far as I know they're all the same bolt thread.
    The total price was dirt cheap (about 30 quid), which made me laugh out loud at the price quoted above for the converter plate sold by CMSNL.
    I'm using a Mann filter.
  15. Dave in Ireland
    Ireland
    Further to above, the filter I'm currently using is a Mann W67/1, which is a short body. I also have a W610/3 longer bodied one for the next change.
  16. Franz
    I will get of E bay plenty of Divvy parts on there.
