Yamaha tank emblem
Discussion in 'XJ Technical Chat' started by Plug, Nov 18, 2017.
  1. Plug
    Plug Active Member
    Missouri
    82 750 Seca......the Yamaha emblem on the tank is coming loose. The Y and the A are loose. What should I use to reattach? Afraid of using a super glue or other cyno based due to the inevitable white fogging. Thinking double sided tape will make it stick out to far. Any ideas?
  2. JetmechMarty
    JetmechMarty Active Member
    Coldwater, Mississippi
    The part number is very similar to the XS650 part number. If you'd like, I can measure the distance between the mount screws for you. If it's a match, Mike's XS has reproduction emblems in silver or gold.
  3. Plug
    Plug Active Member
    Missouri
    Thanks, but there are no mount screws, it is adhesive only 20171118_075626.jpg
  4. JetmechMarty
    Plug likes this.
  5. XJ550H
    chacal sells a glue for fixing emblems
    Plug likes this.
  6. hogfiddles
    A dab of RTV
    Plug likes this.
