Yamaha XJ 900f Self Cancelling Indicators.
Discussion in 'XJ Technical Chat' started by Franz, May 19, 2017.
  1. Franz
    Hi everyone
    Can you give me an idea of how the self cancelling indicators work on the XJ 900F as I have to cancel mine at the handlebar switch?
  2. chacal
    The SELF-CANCELLER UNIT is a rectangular, sealed, rubber-coated box with 6 wires coming out of it into a connector: a solid tan wire, two (2) white wires with a green tracer stripe, a yellow wire with a green tracer stripe, a yellow wire with a red tracer stripe, and a white wire with a red tracer stripe.
    By the way, the self-canceller operates off both time AND distance measurements to determine when it should cancel the flashers.....a minimum of 10 seconds time and 150 meters (about 400 feet) distance. BOTH criteria must be met before the canceller releases the signal flasher:
    http://www.xjbikes.com/forums/threads/help-with-automatic-cancel.81440/
  3. Franz
    Thanks Chacal I am switching the indicators off by hand too soon so I will leave them tomorrow and see if they cancel themselves. Silly me how can they cancel when I am doing it for the cancelling unit.
  4. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    It is good practice to cancel the indicators yourself. The self cancel is only their for backup if you forget.
  5. Franz
    Yes lostboy the XJ is the first bike I have had with self cancelling indicators.
  6. Timbox
    Timbox Well-Known Member
    Ya I am not too sure how I feel about the xj and that feature. I miss the "push to stop flashing" most other bikes have. I will have to either get used to it or deal with it some day.
  7. k-moe
    You can still push to cancel (and I do), but the self-cancel keeps you from looking like an idiot if you should happen to forget to cancel your signal.
    Yamaha used two different types of turn signal switch; one that you push in, and on that you push down on. I'm not sure which was used on the X.
