yamaha xj750 seca engine
Discussion in 'XJ Technical Chat' started by sydmac, Feb 22, 2020.
  1. sydmac
    sydmac New Member
    ireland
    Hi lads, i've put a 750 seca engine in my maxim, can someone tell me is there supposed to be
    a plate covering the main air#80 and pilot air#225 under the diaphram in rhe carbs. im using the maxim carbs in the seca engine. main jet #120 pilot 40. it shows a plate covering the main air and pilot air in the seca carbs but not in the maxim CMSNL schematics. Thanks.
    plate is a part yamaha used then stopped using it is not needed
    Same jets are used in 750 maxim and seca
    if you look at this link you will see specs for US bikes. also Canadain and Euro Seca which have different jets. the US bikes had to meet EPA requirments. That is why there is a difference.
    What you have will work fine.
    http://xjbikes.wikidot.com/carb-specs
    XJ750 Models:
    Years & Models: 1981-3 XJ750 Maxim, Midnight Maxim, and Seca USA models
    Carb Manufacturer: Hitachi
    Carb Series: HSC32
    Carb Model ID: 15R00 (Maxim, Midnight Maxim)
    Carb Model ID: 5G200 (Seca)
    Main FUEL Jet Size: #120
    Pilot FUEL Jet Size: #40
    Main AIR Jet Size: #80
    Pilot AIR Jet Size: #225
    AIR COMPENSATOR Jet Size: #36
    Starter FUEL Jet Size: #40 (non-replaceable, in float bowl)
    Main jet NEEDLE ID: #Y-13
    Main needle JET Size: #3.2mm (the main needle JET is also known as the "power valve" or "emulsion tube").
    Fuel Level in float bowls: 3mm +/- 1mm (.118" +/- .039")
    Idle RPM's: 1,050 rpms
  3. sydmac
    sydmac New Member
    ireland
  4. sydmac
    sydmac New Member
    ireland
    Thank you, while im here, did i read somewhere that the main air and main pilot air jets are
    wrongly shown fitted in the haynes manual.Thanks.
  5. XJ550H
    yes Haynes is wrong jets.jpg this is corrected photo
  6. sydmac
    sydmac New Member
    ireland
    thanks, so pilot large will be 80, small 225 and are you saying this hole needs planking?? Thanks
  7. sydmac
    sydmac New Member
    ireland
    [QUOTE="sydmac, post: 637500, member: 15253"/QUOTE]
  8. sydmac
    sydmac New Member
    ireland
    Thanks so will it be Pilot large 80, small 225 and is the hole to be blanked? Thanks again.
  9. XJ550H
    if by planking you meen the cover that goes over air jets , no it is not needed. the screw is not needed as the hole for screw goes no where
    for hatachi carbs the number is a metric drill size
    main air jet is smallest diameter #80
  10. sydmac
    sydmac New Member
    ireland
  11. XJ550H
    just like in photo the Main AIR Jet Size: #80 goes closest to the screw hole for plate
