Yet another gas-in-the-oil question
Discussion in 'XJ Technical Chat' started by Wendall79, Jun 21, 2007.
  1. Wendall79
    Wendall79 New Member
    Des Moines, IA
    So I just got my bike back from the shop after a very expense tune-up and repair job. I had been getting gas in the oil, and the shop basically rebuild the carbs (amoung other things). I don't know if they inspected the petcock valve.
    I rode it for while, then opened the oil filler cap to smeill for any gas odors. Sure enough, I could smell gas. Could this be residual, or should any residual odor quickly disapper?
    I was wondering if anyone still had the problem of gas in the oil even after carbs were cleaned and rebuilt.
  2. Robert
    I'm pretty sure your gonna smell gas since blow-by will occur even with a fresh oil change. A light odor to be sure, not fumes right out of the tank. I think you have residual because I'll bet dollars to doughnuts that they didn't drain out all of the oil from your crankcase (middle drive drain plug is a mystery to most shops).
  3. RickCoMatic
    The crankcase is under constant, light-vacuum, venting ... at the airbox.
    I'd be alarmed if there was an odor of gas from the crankcase; particularly after having the bike serviced very recently.
  4. Nick
    Nick Member
    Vernon, BC Canada
    I would say it's very possible to have this happen.
    I did my carbs and rebuilt the fuel petcock and still had it happen to me, just once, haven't had any problems since.
    Prior to starting my bike I check my site glass oil level, making sure it didn't mysteriously fill up on it's own!
