Yet another problem. Stupid mirrors
Discussion in 'XJ Technical Chat' started by corner27, Jun 18, 2008.
  1. corner27
    corner27 Member
    Manitoba, Canada
    I took the mirrors off my bike, and it seems like the threds in the holes are completly shot. Is there any quick fix for this?
  2. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    a re-threader or helicoil
  3. MiCarl
    Yamaha uses a left hand thread on the right side mirror.
    I suspect you'll have a hard time finding a left handed helicoil.
    If you fix the threads you'll probably have to replace the mirror.
  4. corner27
    corner27 Member
    Manitoba, Canada
    It's pretty much just the left side that I need to fix. The right seems to be holding good. Why will I need to replace the mirror?
  5. MiCarl
    The right mirror has a left hand thread on the stalk. If you put a right hand insert in the mount the stalk won't thread in anymore.
    The LH mirror uses a right hand thread. That one you can stick a helicoil in and be just fine.
  6. PaintIt(Flat)Black
    PaintIt(Flat)Black Member
    Sterling, MA
    It should be a 10mm X 1.25 tap you need, it's a finer thread... make sure it's not the 10mm X 1.50.
    If it is only the left mirror it should be Right Hand Thread and a hardware shop may have it.
    OR!!! you can do what i did today, take of the piece and bring it to a local machine shop (hopefully you have one) and have them tap it out for you. Luckily I knew the guy and he did it for free.
  7. leadboots
    leadboots Member
    aylmer ontario canada
    JB weld
  8. PaintIt(Flat)Black
    Sterling, MA
    Actually once i got mine in right where i wanted them i did put on some industrial strength glue :D gotta love that stuff!
  9. corner27
    corner27 Member
    Manitoba, Canada
    I did the JB weld, so we'll see if it will hold. If not I'll have to try and retap, and if that doesnt work, I'll put a new insert in
  10. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    JB weld will hold if mixed well and left to set for atleast 24 hours. I broke my front brake lever and used JB weld to repair it. It holds good and solid. I tried like hell to break the weld, but can't do it. So I figured it should be a safe enough fix.
    Once you install the mirror with JB Weld, you shouldn't have to worry about getting it back off without using a pipe wrench!!
