YICS tool
Discussion in 'XJ Technical Chat' started by FastMaxim82, Jan 1, 2009.
  1. FastMaxim82
    FastMaxim82 Member
    Tarentum, north of pittsburgh, pa
    Just curious, but what exactly is a YICS tool that people say is needed to adjust the carbs. And is there a fuel/air adjustment on a 82 550 maxim? It has Mikuni carbs. I've synced my carbs beforei was just wandering what the purpose of that tool is.
  2. MiCarl
    YICS is a narrow passage in the head that interconnects the four intakes. It's supposed to work some kind of performance or emissions miracle. The YICS tool is used to block the passage when synchronizing carburetors.
    Your Mikuni carburetors have a fuel screw. It's located on the top of the carburetor at the front near the enrichener valve. It might be covered by a brass plug.
  3. FastMaxim82
    FastMaxim82 Member
    Is the YICS tool absolutley needed to sync the carbs? Thanks for the tip on the fuel screw, i'll probably leave it alone since the bike ran awsome last year and still got 62 mpg. I was just curious since the yamaha info said "no adjustment"
  4. SQLGuy
    SQLGuy Well-Known Member
    The answer is pretty much "Yes".
    When the bike is running normally, the YICS passage allows each intake port to draw a bit from the other three ports. So, if the YICS passage is not blocked off when synching, adjusting one carburetor is going to affect the vacuum levels of all the ports, not just the one it's connected to.
    I suppose you could eventually get things synched without it, but it would be a much more frustrating trial and error process.
  5. MiCarl
    I think the YICS tool makes your set up more precise. Since there YICS passage interconnects the carbs it will tend to mask some minor sync issues.
    Be sure to check the valve lash or syncing is a waste of time.
    Yamaha put the plugs on and said "no adjustment" to keep the EPA happy. My motto is "if it ain't broke don't fix it".
  6. FastMaxim82
    FastMaxim82 Member
    hench why each time i came back to a carb the vacuum was different than when i had left it. I see I see. Guess i'll have to find one of those tools. Man, she should run really good this year then. lol
  7. SQLGuy
  8. Fishmaster
    Fishmaster Member
    Spring, TX
    If you use Colortune to adjust the mix, are you still need the YICS tool?
  9. chacal
    That diagram on the crc2 website is not fully correct. It is missing the large sealing washer that needs to be on the end of the tool where it enters the YICS chamber; otherwise, you'll have a massive air - vacuum leak on that one cylinder, and you'll never get a proper synch accomplished!
    And yes, you still need the YICS port blanking tool, even when (or especially when) using a Colortune. The purpose of the port blanking tool is to segregate each cylinder from all the others (which the YICS chamber joins together by design) during synch and carb tuning procedures, so that each cylinder "stands on its own two feet" (fins?) during the tuning procedure.
  10. Fishmaster
    Fishmaster Member
    Spring, TX
    do you use the same tool in all XJ models?
  11. chacal
    Yes, as long as it is a YICS-equipped engine.
  12. ethanch
    ethanch Member
    Spokane, WA
    so where can I buy a YICS tool? can someone post a link please. Chacal gave me no hits on google. Thanks,
  13. Robert
    Chacal sells them (cheap too) and you can make one with the plans set out in our DITY section.
  14. bill
    bill Active Member
    Raleigh, NC
    Chacal is a forum member. PM him or see his thread a the top of the forum index
  15. Deadulus
    Deadulus Member
    Dufur, Oregon
    Ethanch, look just above your last post....thats Chacal.... :grin:
  16. TheHound
    TheHound Active Member
    Scotia, NY
    hehehehe Chacal the mystery man.
  17. HalfCentury
    HalfCentury Member
    Virginia Beach, VA
    I bought my YICS tool from chacal. Works great.
    Make sure to spray the YICS tool with silicone lube every time you use it.
    The YICS passage will be filthy. Clean it with a rifle cleaning kit that you can purchase at your local gun supply spot.
