YIKES!: ALL ABOUT THE "YICS" SYSTEM.
Discussion in 'XJ4Ever - Supporting Vendor' started by chacal, Jan 1, 2009.
Thread Status:
Not open for further replies.
  1. chacal
    YICS AND WHY YOU SHOULD LOVE IT:
    Yikes! It's a YICS!
    YICS stands for the Yamaha Induction Control System and is a performance and fuel-efficiency-enhancing cylinder head design that promotes better and more complete combustion chamber "filling" and "mixing", and thus better combustion efficiency via a cast-in, full-length, 10mm diameter chamber within the back top edge of the cylinder jugs connected to special passageways within the cylinder head. This chamber is sealed with a small hex-headed bolt ("plug") and sealing washer at each end, and within the chamber has 4 individual tiny holes (or "sub-intake ports", as Yamaha calls them) that lead up into the cylinder head's main intake passageway.
    YICS made it's first appearance on various 1981 models, and was used until 1986.
    Interestingly, about the same time that Yamaha was developing (1978-79) and implementing (1981) this system for their engines, Honda (the auto company) had recently introduced their "3-valves-per-cylinder" concept on their CVCC engine design (which stands for Compound Vortex Controlled Combustion). This system used an ultra-rich fuel mixture, which entered into a very small, segregated combustion chamber which enveloped the spark plug, and via a separate intake valve, received this very rich fuel mixture from a separate venturi from a common carburetor.
    The main fuel charge was ultra-lean, and entered the main combustion chamber thru a much smaller 2nd intake valve.
    The spark plug ignited the tiny ultra-rich mixture, which then propagated outward through a small passageway from the small "rich-mixture" combustion chamber into the much larger main (lean-mixture) cylinder chamber, and it was this traveling, swirling wall of flame which actually ignited the main (lean) fuel mixture. The "swirl" initiated by the rich fuel mixture flame front into the main combustion chamber closely mimics the purpose of the YICS system as described below.
    Honda was so successful with this development, that they were able to exceed US emissions standards with these CVCC engines by a full 3 years or so, and were the only US-sold automobile that did not employ the use of catalytic converters in order to meet emissions requirements.
    Here is how Yamaha describes their YICS system:
    "The YICS consists of 2 separate chambers, each connected, to a port on each cylinder just behind the intake valve. As the piston moves down on the intake stroke, the cylinder fills with a fresh air/fuel charge. A vacuum is also created in the YICS chamber at the same time. When the intake valve closes, part of the charge is drawn into the YICS. When the intake valve reopens the mixture in the YICS shoots back out through an angled tube into the cylinder, mixing with and swirling the main intake charge. The swirling charge is then compressed and ignited, burning more completely and producing more power than that of a conventional engine."
    These YICS sub-intake ports have approximately 1/4th the cross-sectional area of the main intake port runners. These smaller YICS ports tie into and enter the main runners just above the intake valve seat in the combustion chamber and at such an angle that their air/fuel "charge" is directed around the outside walls of the cylinder/cylinder head/combustion chamber, which results in a swirling effect as the mixture is drawn in and then compressed via the piston.
    These "sub-intake ports" are connected via the YICS cylinder head passage. Since only one cylinder is on the (downward) intake stroke at any one time, the YICS sub-intake port FOR THAT CYLINDER also draws in some air/fuel mixture charge from the other three sub-intake ports and carbs. When a piston is moving down in the cylinder bore during its intake stroke, the vacuum created operates on both the main intake port (for that cylinder) AND on all the other sub-intake (YICS) ports. But since the area of the sub-intake port is so much smaller than the main intake port, this sub-mixture moves through the YICS passage/port almost 4 times faster than through the main intake port. Thus the cylinder "filling" and "swirling" effects......
    According the factory marketing gurus, the end result of this controlled turbulence in the combustion chamber is quicker, more complete burning of the air-fuel charge, and thus, all (well, at least "more") of the power contained within the fuel is liberated on every power stroke of the engine.
    Note that in all of this discussion by Yamaha, that the underlying theme is "greater fuel efficiency", and NOT one of more power or performance--------although the two do go hand-in-hand.
    Perhaps it is telling that the only difference between the 1980-81 XJ650 Maxim carbs (non-YICS) and the 1982-83 XJ650 Maxim carbs (YICS) is that the air jets were increased in size by almost 15% on the YICS versions----resulting in a leaner fuel mixture----without any decrease in power. A leaner overall fuel mixture----just as Honda discovered with their CVCC system----results in better fuel economy with the same amount of power output.
    Things Go Better With YICS, At Least On These Models:
    YICS was used on:
    * all XJ550 models
    * all 1982-up XJ650 Maxim and Turbo models
    * all XJ700 air-cooled models
    * all XJ750 air-cooled models
    * XJ900RK
    * XJ1100 models.
    Strangely, the 1980-81 XJ650 Maxim and XJ650 Midnight Maxim models, as well as the 1982 XJ650RJ Seca models, did NOT use the YICS system. It has also been reported by some owners that some very early model 1982 XJ650 Maxim models did not use the YICS system.
    Most YICS-engined bikes have front lower (oil pump) covers on both sides that features a red, rectangular "YICS" emblem in them below the cast-in YAMAHA wording....the XJ700 air-cooled models being an exception to this rule. Non-YICS engines have the oil pump covers with only the YAMAHA wording (or no wording at all) cast into the cover.
    YICS-engined bikes use a valve cover that has the word YICS cast into the top surface, while non-YICS models are blank or are cast "YAMAHA" (or "YAMAHA 5VALVE" on 700-X/750-X models) on the valve cover.
    YICS-equipped engines have a full-length chamber cast into the rear, top section of the cylinder jugs, sealed off by a bolt (and crush washer) at each end of this chamber. Non-YICS engines have no such port.
    YICS-engined bikes have the valvecover secured to the cylinder head via a total of 12 bolts (and each of these bolts has a special cone-shaped rubber "pressure washer" under each bolt head). Non-YICS engines use 20 bolts to secure the valvecover, and no "pressure washers" on the bolts. There are, of course, exceptions: the XJ650 Turbo engine and the XJ1100 engines; while they are YICS engines...and have YICS cast into their valvecovers....they use 20 bolts instead of 12, and thus no pressure washers.
    YICS-engines use a soft, spongy-rubber valvecover gasket (except, of course, the XJ650 Turbo and XJ1100 engines), while the non-YICS engines use a flat "paper" gasket (except for the XJ700-water-cooled engines; they are not a YICS engine, but they too use a soft rubber valve cover gasket and pressure washers.
    Professional tip: just look for the word YICS on the valvecover, it’s the easiest way………and although you could come across an XJ650 Turbo (YICS) valvecover on a non-yics XJ650 (1980-81 Maxim and 1982 XJ650RJ Seca) engine, the chances of that happening are between slim and none………!
    Here is how we describe their YICS system:
    YICS is probably a good feature, and probably does provide some moderate advantage in fuel economy and performance, just as the factory claims. It adds an additional step.....and tool.....to the engine synch procedure, as a YICS passage "blanking" or block-off tool must be used when doing a synch, and it's also not a bad idea to clean out the tiny YICS chamber port holes every once in a while, and to replace the YICS passage bolt Sealing Washers every so often; but other than that, it's a pretty simple and problem-free system; because, as Yamaha likes to say, "we did all this without adding any moving parts!".
    An Insight From One Who Knows:
    To review:
    According to Yamaha, the function of YICS is to promote more complete combustion at low to mid-range rpm by swirling the mixture around the combustion chamber. They never made any direct power claims -- the system was promoted as increasing mileage up to 10 percent and promoting lower emissions through a cleaner burning charge. The increase in mileage was not through leaning out the mixture -- the increase in mileage and reduction in emissions was because less throttle was required to maintain cruising speed. They could use the same cam timing, jetting, etc. (for performance) and still meet EPA regulations. Yamaha stated that the greatest effect was while cruising at 50 to 60 mph.
    The swirling accomplishes two tasks: first, it assists mechanically in atomization of the fuel and second it speeds and distributes the flame front (and therefore combustion pressure wave) more evenly throughout the cylinder. The later "Genesis" (water-cooled "X" engines) design accomplished this even more effectively through the 5-valve design, which accomplishes the same task through a wider rpm range.
    To blank or not to blank (during engine synch), that is the question. Ok, what is the function of synchronizing? Manufacturing tolerances and wear. Multiple carbs offer the advantage of increased power and performance over the single carb configuration for reasons beyond the scope of this discussion. But at a cost.....
    As each carb is dealing with a fraction of the total air and fuel flow requirement, each carb must meter things in fractions of the total. That makes for some very tiny tolerances. In effect, we have 4 separate engines -- if one is fighting the others, then we are wasting power and fuel and are worse off than we would be with a single-carb setup! So it is crucial that each one be perfectly adjusted and that all 4 then be synchronized to work in perfect harmony.
    So, how can we reliably adjust an individual carb based on the results of the adjustments, if it's companions are contributing to the results? Now, to be fair-----if the bike has been reasonably well maintained and the cylinders are all fairly close to begin with, you can usually get away without blanking the YICS passage and still achieve a reasonable state of tune. At the opposite end of the maintenance spectrum, the YICS passages are often already plugged up with many years worth of accumulated grunge and grime, so the bike is effectively being tuned with the YICS system disabled and the presence of the tool is irrelevant. But we have seen some examples of carbs where one cylinder was effectively relying on its neighbors to supply most of the mixture through the YICS system, and this most certainly affects performance, especially the top end.
    Take a look for yourself:
    So, my recommendation: for an engine with approximately equal compression across the cylinders and valve clearances in spec, make sure the YICS passages are clean and use the blanking tool to tune the carbs.
    The most important point to remember:
    The pronunciation of "YICS" is "yiks", not "yikes!", no matter what anyone else tells you!
Thread Status:
