YOO-HOO, 700 OWNERS!!
Discussion in 'XJ Technical Chat' started by chacal, Apr 23, 2009.
  1. chacal
    I've got a question about the factory CRASH BARS (or "engine guards" as they are sometimes called).
    I know that the factory bars that were used on the X-models were only available in a 2-point style, and one of the mounting flanges had this funny little offset "stepped" shape to it for proper frame clearance.
    Question is: did the 700 non-X (air-cooled) models also use this same set of guards, or did the non-X models use the more conventional, standard style bars (as used on the 550, 650, 750, 900 models)?
    Does anyone have a set of 700 non-X original Yamaha guards on their bike?
    Thanks.
  2. mcrwt644
    mcrwt644 Member
    Winchester, VA
    As with MOST things from xj700 to xj700x, parts will interchange. Heck, I have a full exhaust from an xj700 on my x even though part numbers differ. The frames are ALMOST identical with the exception of where and how the harness routes near the steering neck. The guards will interchange. I have a friend who has an xj550 that has my xj700 guards on his bike. Chacal, was this what you were looking for?
  3. chacal
    Well, sorta. I was looking more for actual information, maybe even part numbers, to verify the applications, or at least a real-world "had it on the bike and it fit fine" type of thing (although I agree with your interchange sentiments entirely).
  4. midnightblu
    midnightblu Member
    Austin, TX
    well i looked and diddnt see a part number on mine .. i'll check the fische for you later
