TURBOCHARGED MAXIM 650 BUILD
Discussion in 'XJ Modifications' started by farmer, Sep 23, 2009.
  1. farmer
    farmer Member
    Here is the start of my build thread. Taking a turbo seca 650 motor and transplanting it into grandpa's 1981 maxim 650.
    Dont have any pictures yet but will update as the build progresses
    Turbo Mods include:
    -T25 turbo from a saab relocated to front of bike
    -Custom made stainless Front mount turbo header
    -An actual blow off valve the relives after each shift, not a bov that only vents after 15psi to save the engine.
    -Autometer boost guage
    -Wideband air/fuel ratio guage
    -Seca turbo fuel pump and wiring, turbo petcock with return line
    -Seca turbo boost and knock sensor
    -Seca turbo anti-lag airbox plenum with disabled blow-off valve
    -Seca turbo ignition box and coils
    -Seca turbo oil cooler
    -Custom supply and return lines for t25 turbo
    -Seca turbo 650 engine with ported exhaust ports
    -6psi base boost
    Turbo stage 2:
    -water injection
    -front mount intercooler
    -boost controller, higher boost
    Turbo stage 3:
    -900 big bore?
    -700n exhaust cam?
    Powertrain/frame:
    -Seca turbo front rim with dual disc upgrade
    -Seca turbo rear rim with higher tire for higher better gearing
    -Larger seca turbo rear brake drum
    -stock maxim crash bars with highway pegs
    maxim 750 tank with custom airbrushed painting of grandpa (he was a pipeline welder, some picture of him welding in his helmet.)
    Electrical:
    -Led Brake light and license plate light (save some amps)
    Will update when pics are available! Should be in a few days. Hope to have this done over winter. Still riding the bike, will start the teardown in less than a month.
  2. TIMEtoRIDE
    COOL !! some Real modifications to look at.
    Get a pic of the full mock-up, even if you have to tape things in place.
  3. maxhog650
    maxhog650 Member
    Boulder, Colorado
    sounds crazy if it works, cant wait for pics to start coming in. good luck
  4. farmer
    farmer Member
    Heres some pics
    Enjoy.
    Next is to order the 1 inch stainless piping and mandrels and flanges for the exhaust header, wire in the new CDI box and coils to confirm my wiring is correct and that the cdi box runs the old motor, swap the motor, then start the turbo header fabrication!
    Any comments appreciated.
      File size:
      15.4 KB
      15,471
      File size:
      37.3 KB
      15,474
      File size:
      36.2 KB
      15,469
      File size:
      43.5 KB
      15,473
  5. 7kidsathome
    7kidsathome New Member
    I saw where a guy did this same setup on the turbo motorcycles forum, except he used a long tube header. Where are you going to get the header pipes and flange from?
  6. Raven
    Raven Member
    Twin Cities, MN
    Man, that's awesome! I gotta ask a couple questions :)
    What are you using for fuel management? The seca turbo electronics, or are you going to add something like a rising rate FPR?
    If you go so far as to add a FMIC, you could probably find a stock side-mount from a 300ZX and get it to work.
    I find this stuff really interesting, I'm excited to see what you come up with!
  7. farmer
    farmer Member
    7kidsathome -- he did this to a maxim? Do you have the link, did he have any pics? Getting the stainless pipe from mandrelbends.com
    turbo flange will be made up, header pipe flange i am going to cut the stock flanges and weld them onto the new stainless header.
    Raven -- Using the seca turbo electronics, carbs, fuel pump, etc. I will add the FMIC once i get it working with low boost.
  8. TIMEtoRIDE
    Have you hooked up with OrganizedInsanity yet??
    He's doing this build
    Do you have a Turbo motor??
    I have one. a "regular" motor might grenade after 100 HP
    The "turbo" motors have specially hardened gears and extra case webbing.
    You seem to want to exceed 15 PSI right ?
  9. SecaRob
    SecaRob Member
    Cincinnati, Ohio
    Oh how I would love to see Wiz incorporate one of these into his 900 build.
  10. 7kidsathome
  11. farmer
    farmer Member
    TIMEtoRIDE -- yes i have a complete turbo seca motor + setup. the pic of the motor above is a turbo motor
    Id like to see Wiz's build thread.
    7kids -- Ya i did see that. i posted to that thread. wanted to see pics. The front mount will allow so much more heat into the turbo than at the rear of the bike. The front mount will be tight especially when the front fork compresses. IM hoping i can get the turbo low enough to keep it out the the wheels way on compression, yet high enough not to hurt ground clearance.
    We shall see what happens.
    Just got my 750 tank today and my parts for my twin disc front brake setup!
  12. 7kidsathome
    I was just thinking, so what if you have a regular motor. If you have enough fuel and keep boost sane with an intercooler, water injection and the other key parts (BOV/BPV) you could turbo a regular SECA/Maxim motor. I know the pistons are an issue, but remember they were built for abuse to begin with. If you keep it wet and cool it should be possible.
    Most of the high hp turbo motors (auto/bike) run 9:1+ compression anyway. How many turbo bikes have the "standard" 8:1? Most Kawi and Zuki's have 9:1+ compression and stock pistons. Just a thought, especially with your stages of build. Boost is low to start. Injection and Intercooler later, then the big guns come out with the 900 build. I saw the 700N cam is done by several people on the 650 Turbo and has produced favorable results. Let us know what happens.
  13. farmer
    farmer Member
    A small update but still an update none the less.
    Turbo seca motor is installed in the maxim frame. I also managed to get the seca turbo ignition box wired up and it is producing spark! So I am happy for that as I felt that was my biggest obstacle. Getting the wiring correct. It was easy. All that was needed was to change the one connector on the maxim ignition box and replace it with the larger connector of the seca.
    I still have to wire in the knock and boost sensors but, my main concern was getting that box sparking.
    I am also going with a VNT15 turbo, commonly found on 98+ jetta tdi. I have been informed my gt25 turbo is much too big and will not spool until 10,500 rpm. I am told the GT12 garret turbo is a suitable size, but I am going with a VNT15 which is slightly larger but I am hoping the Variable Nozzle assembly will help spool times.
    I am now going to order the mandrel bends from mandrelbends.com. I am going with 1 inch diameter primaries which is slighly larger than the inner pipe diameter of the stock seca turbo headers.
    Stay tuned for more updates.
  14. schooter
    cool story bro
  15. farmer
    farmer Member
    small update, no pics....yet.
    -Was able to fit the fuel pump under the frame right above the airbox. Making custom brackets to utilize the stock rubber vibe mount for the pump.
    -Getting a new piece lasercut out of aluminum for the airbox reed valve assembly. The outer piece where the filter attaches hits the battery box so I am making a new piece which will move it over to the other side. Also welded up the stock airbox relief valve and fitting a true BOV.
    -Mocked up the turbo fuel petcock. One of two holes fit the stock tank. (which is actually a maxim 750 tank.) it has a fuel level sensor so i will also hook that up somewhere. So now i have to somehow tig the tank to move the other bolthole over about a 1/4 inch. that should be fun. But it has enough clearance when mounted to the bike frame along with the fuel pump. This will proably be the hardest part of the swap.
    -Ordered an intercooler. Might as well intercool right from the start.
    -Piping should be here anyday then header construction can start.
    -Getting a new flange CADed up for the oil return as it needs to point to the front of the bike, not the back,
    -Got the turbo flanges being CADed also.
    -Installed the seca throttle cable which is needed for these carbs. The choke cable needs to be longer and the seca one is still to short, at least with the stock maxim bullhorn handlebars. Im changing these to straighter ones one day.
    Thats about it so far. More pics to follow shortly.
  16. schooter
    cool man sounds like you really know what you're doing, cant wait
  17. farmer
    farmer Member
    ok some updates.
    -intercooler mocked up for now, started to make the header, just waiting on the compressor center section of the turbo to determine the turbo location and make the header.
    -removed the oil pan to flush it. got the oil flange cadded also for the oil return.
  18. 81seca550
    81seca550 Member
    York,PA
    Thats gonna be a monster of and XJ sir. Seems like your making great progress. I would love to see a video of this monstar running when she is finnished.
    Good luck and may you not run into any complications and may you have her on the road by spring
  19. huckersteve
    huckersteve Member
    Seattle, WA
    Phenomenal work! Keep it coming! What do you have planned for cosmetics for this project?
  20. Grieverlust
    Grieverlust New Member
    I bet this bike will sound friggin awesome when its done! Keeping an eye on it. Good luck!
  21. farmer
    farmer Member
    update: First setback. I need to somehow limit my front fork travel about 3 inches to prevent it from hitting the intercooler. There is one pic of the suspension fully compressed. see pics below. turbo in preliminary spot, header construction will start soon once i get the collector jog finished and build the collector. gonna be a tight fit.
    Any thoughts?
    Cosmetics: not much for now. It might be cool to incorporate the seca turbo front lower fairing but i dont think thats possible. too tight. im getting some non bullhorn handlebars. Perhaps a headlight chrome cap. And eventaully powdercoating the frame. Any recommendations?
  22. farmer
    farmer Member
    Here is a small update of header progress. Doesnt look like much but its getting there. Very tight clearances to work with.
  23. schooter
    oh la la
    just a thought, this would be a good bit of work, but perhaps a small bit of raking to add more room?
  24. lowlifexj
    lowlifexj Member
    Grand Haven,MI
    I was thinking the same thing then got down to your post schooter..
    A little more rake might help keep that front end on the ground when you hit half throttle :lol:
    Looks really neat farmer I am impressed to say the least..
    Is there another xj or yamaha that has the same diameter tube but in a longer length that you could install into your down tubes then use a spacer to take up the extra length up top so you would still have the travel the front would just sit up higher?????
    I don't know just throwing ideas out :)
    Good Luck,
    James
  25. farmer
    farmer Member
    ok, slow going but the header is almost tacked in place. not the best pics. have 1 runner left to do. very tight clearances, more pie cuts that i would have liked, tried to keep using mostly mandrels. will look better once tigged as i used the mig to tack it. the runner on the left of the first pic i need to massage a little more yet, but its getting there.
    the main thing is that it fits in place. then i have to modify the vnt actuator to work in reverse, as well as rig up something to relocate it as it will not fit on the stock bracket.
    getting there!
  26. shnuffy
    shnuffy Member
    Guelph, Ontario
    Woah, that is badass. Great work!
  27. schooter
    damn, thats a good bit of engineering
  28. farmer
    farmer Member
    Just a quick view of all 4 runers tacked from the front looking through the forks.
    Getting excited to fire!
  29. schooter
    wow, that thing's crazy, good luck man
  30. xj650_dude
    xj650_dude Member
    Boise Idaho
    so sick! Real good stuff!
  31. Orange-n-Black
    There's a shop near me that sells degree rake kits, here is the web site.
    WWW.chopper-kit-usa.com
    They have 9,14 and 18 degree kits for Virago, same front end as XJ.
  32. farmer
    farmer Member
    Thats a cool idea for the rake kit.
    However, I managed to make it just clear, and my next thought is using a maxim x front end to get the larger 38mm shocks and factory fork brace.
    Then hopefully fit turbo xj wheels all around if I make it that far.
    Slow progress as usual my welder is out of town.
    But here is the header off the bike....
  33. cutlass79500
    lawrenceville georgia
    its definately going to be different hope it turns out as good as all the pics look and your happy with it
  34. schooter
    dang, that's wild
  35. rockerto
    rockerto Member
    Toowoomba, Queensland
    Not easy but possible to do, thanks for showing that.
    How far off is it from equal lengths? (Tuned header)
    A piece of string with a nut tied to the end dropped down each pipe till it touched the turbo rotor would give you a rough idea of the exhaust path length.
    Thumbs up Farmer, good work.
    I'm a welder, wish i was there.
  36. mrtim123
    mrtim123 Member
    Newcastle, Australia
    anyone know what ever happened to this build? would be good to see how it all ended up :)
  37. farmer
    farmer Member
    Havent been on in probably over a year since today and I see my thread is still on the first page.
    No progress as of yet, hope to get back it again this summer.
    Just acquired a Maxim X front end and triple tree, im hoping that will bolt right into the front frame. Anyone know if the seca turbo 650 front wheels brake spacing will work with the maxim x forks and and brake caliper spacing? will the rotors line up with the calipers?
    thanks
    will keep posting update.
  38. Ledicott96
    Ledicott96 Member
    North west England
    Should do if the wheels are the same size.
    Al
  39. 82maxim
    82maxim New Member
    South Lebanon, OH
    I'm about to start the same build when I came across your's, you having any luck with it?
  40. farmer
    farmer Member
    yearly update. finally found time to work on this more. header almost complete. oil cooler bracket made and oil cooler mounted.
    now just need custom braided oil cooler lines and make an oil return and it should be ready for a test fire.!
    hopefully this summer will be on the road.
  41. farmer
    farmer Member
    Finally Some long awaited updates:
    We are getting close to being able to fire this thing. Totally rebuilt the carbs last weekend.
    I need my custom stainless braided lines made up for the oil cooler, fill the case with oil, and it should be close to being able to perform a test fire. After successfully test firing I will then complete the last pieces to getting it running, The air intake piping for the turbo, The charge piping from the turbo to intercooler to plenum, and the exhaust. Then we can see how this thing reacts to boost from a GT15 turbo from a VW TDI with VNT control on the vanes. I hope to be able to spool up and get that front wheel off the ground in 1st gear.
    Onto the pics:
    Turbo petcock mount plate welded onto a 750 maxim tank...
    One pic of the proposed wastegate and air filter placement.
    Another of just the bike sitting out in the snow.
    And finally a pic of the key/cluster. For this what I did was I used a maxim X/700n triple tree and forks and my stock key/ignition. Unfortuately what this did was angle the key so that the steering lock no longer works. Does anyone know if i were to get a maxim x/700n ignition assembly would it fix my steering lock issue.
    I want to do a custom dash plate with FZR gauges, but my one problem is that I am from Canada, and I am having trouble locating a FZR cluster with KM face. I suppose I could always swap to this later.
    On antother note, does anyone know if the FZR fuel gauge is compatible with the Maxim 750 fuel gauge sender?
  42. 750E-II_29Rbloke
    South Cheshire, UK
    That looks a beast, love what you're doing & will be following the build. Maybe your best bet for KM/H clocks would be Ebay Australia? They seem to get a lot of Japanese imports over there so probably more KM clocks there?
  43. farmer
    farmer Member
    Temp exhaust, for now. Will redo with mandrel bends and stainless.
  44. RickCoMatic
    That Slash-cut for the exhaust might be easier on your left foot if it was extended beyond the foot-rest.
  45. hogfiddles
    I guess it's just a "I wanna do it myself" kind of thing, but I'm wondering why you didn't start with a 650 turbo engine to begin with?
    Dave F
  46. farmer
    farmer Member
    I did start with a turbo 650 engine. Just upgrading/ replacing all inferior components.
    The exhaust again is just temp until I get it going good. If anything will make for a loud foot warmer.
    Did some work today on making the carb mounted choke , using a locking choke plunger from a Yamaha yz80.
  47. hogfiddles
    Oh, ok.......somehow I missed that. Cool.
    Dave F
  48. farmer
    farmer Member
    Update:
    intercooler mounted. Dont know where else to put it, at least its inside the crash bar...
    now to make custom end tanks. also had to cut off the outlet on the compressor and weld in a tight 90 bed to get it to work in that location.
    More updates next week. Getting close to firing.
  49. Foolber
    Foolber Member
    In an Igloo, on Jupiter¿
    pure awesome ness.
  50. biggyfaction
    biggyfaction Member
    cedar rapids iowa
    Can't wait to see how this turns out. i hope you make videos of sound and a ride along. :)
