instrument Cluster to single gauge
Discussion in 'XJ Modifications' started by Shim, Apr 7, 2008.
  1. Shim
    Shim New Member
    Pink, Oklahoma
    Alright guys i am wantin to do away with the speedo/tach cluster and just have a single guage on my 1980 650xj and was wondering if anyone could give me some ideas on what the easiest/best way to do it would be and where i could get a good single guage thanks guys
  2. fr33z3r.burn
    fr33z3r.burn New Member
    East Texas
    I don't think you will find a better answer than this thread by PainterD
    http://xjbikes.com/Forums/viewtopic/t=7806.html
    I did something similar on my Seca 750, but i went with a speedo and a tach. The thing to remember is that you can use just about any Japanese mechanical speedo from the 70's and 80's. It will be up to you to fabricate a mount.
    Ebay is a great place to find speedometers.
  3. Speedwagon
    Speedwagon Member
    Littleton, CO
    So, are ratio adjustments made in the gear that goes on the front wheel then? And for the most part, everything uses the same ratio from the cable to speedometer?
  4. Shim
    Shim New Member
    Pink, Oklahoma
    Alright thanks alot guys i'll go check out ebay
  5. Polock
  6. digitalbroccoli
    digitalbroccoli Member
    sodus ny
    I went with speedo and tach, both from mikesxs.com.
    for comparison...
  7. Robert
    Broccoli, your old gauges looked great! What did you do to keep them in such beautiful shape?
  8. philbrewer
    philbrewer Member
    Livonia, MI
    Did you have to splice the wiring for the new LEDs to work?
  9. cavalry1911
    cavalry1911 New Member
    in relation to that, i'm looking at getting myself a set from mikesxs.com as well for my xj650lh midnight maxim. will the gauges work with my motorcycle as well?
    the part numbers are from mikesxs.com
    Part #03-0749
    Part #03-0748
  10. MadMaxim82
    MadMaxim82 New Member
    Long Beach, CA
    It seems like part #03-0748 from MikesXS is for a 2:1 ratio speedo, seems like it would be significantly off. If I am mistaken let me know, I would love to put those on my bike and minimize the giant cluster while keeping the dummy indicator lights.
    http://www.mikesxs.net/product/03-0748.html
  11. fuggers
    fuggers Member
    I'm in the process of switching to this exact set of gauges. I had to order some T1 connectors to get them to slide into the terminal to connect to the stock harness.
    How did you splice them in, Digitalbrocolli?
