Wanted Carbs needed badly
Discussion in 'For Sale, Trade/Swap, Wanted' started by jofish3, May 13, 2017.
  1. jofish3
    jofish3 New Member
    ga
    Needs a set of carbs for 1980 yamaha maxim xj650 .po said he cleaned them didn't tell me he broke the float stands
  2. hogfiddles
    Well, YEAH--- doesn't everybody know that the way to remove the floats is simply to BREAK everything? Amazing how some people can be so ham-fisted, then try and sell things as:
    "umm, i 'cleaned' it.... yeah- that's the ticket! I 'cleaned' it. Got those pesky towers out of the way, while I was at it........."
    (say that all in your best smarmy John Lovett Pathological Liar voice.........)
    Lol
    Now, seriously--- any '80-'83 xj650/750 carb bodies will work, just make sure to use the right jets, and the correct mixture screw threads.
    To be picky on detail-- the 1980 carb bodies were slightly different: each body only has one bolt for the upper rail and for the lower rail. The other hole in the rails for each body and it does not get a bolt....there is a indexing boss cast on the bodies that fits into those holes.
    Here's a detail pic-
  3. jofish3
    jofish3 New Member
    ga
    Thanks for the info !!
  4. hogfiddles
    Watch the thread I just starts for af226's carbs
    Xjrider92117 likes this.
  5. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    If I'm not mistaken, I believe you might be able to repair the broken float stand. If your talking about where the pin holds the float. If there not to messed up.... I no there was a how to thread on the topic. Google is your friend followed by XJBikes.com.
  6. hogfiddles
    There are lots of ways people have repaired them....
    -some have tried epoxy, jbweld, etc... with mixed results
    Some have milled and dovetailed new blocks in place. Personally, I think those work but look hideous.
    I will NOT send carbs back out with compromised towers. When I find a repair that is as strong as original AND is virtually invisible ( looks original ) then I might be ok with it. Til then, not......
    craiygxj likes this.
  7. TommyCrabtree
    TommyCrabtree Member
    WV
    Two of my carbs had broken pillars that were JB welded by one of the previous owners. When I opened them up both repairs had failed. Here's how I fixed them. This was meant to be a temporary fix until I found a deal on a couple new bodies but it's held up perfectly for over 8 months. The nail is aluminum.
    [​IMG] [​IMG]
  8. mc2burk
    mc2burk New Member
    Lafayette, La
    I have a set of 750 carbs. Engine has starter clutch drive issues. Not sure i wanna tackle that. Lol.
  9. mc2burk
    mc2burk New Member
    Lafayette, La
    Anyway, the whole set is in great shape.
  10. mc2burk
    mc2burk New Member
    Lafayette, La
    What are you concidering paying?
  11. vitovabo
    vitovabo Member
    NE Philly
    I have carbs for a xj650 they were off a running bike, how much are you willing to pay?
  12. joejr2
    Santa Fe,NM
    I have a set of stripped carb bodies still on a rack from an 81 650 maxim. #s 2,3 and 4 are intact
    #1 has a broken float pillar. Interested ? $35 + shipping
  13. Toomanybikes
    Tsawwassen bc
    Have you found any yet?
    I have a few sets of carbs for your 650.
    If you want I can send you a basic set do your own rebuild or a gone to church set or send them to Hogfiddles and he can do them for you.
