Digital Manometer
Discussion in 'XJ Technical Chat' started by Rebem, Apr 8, 2017.
  1. Rebem
    Rebem Member
    Perth, Western Australia
  2. mlew
    mlew Well-Known Member
    Apex, NC
    I use an old school Dwyer differential gauge type manometer(magnehelic) and it works great. No reason that one wont work .
    Rebem likes this.
  3. XJ550H
    we have a member who owns one he likes it
    Rebem likes this.
  4. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    It is NOT a personal safety device.
    JeffK and k-moe like this.
  5. hogfiddles
    I'm content with my Morgan carbtune
  6. PilotSmack
    PilotSmack Active Member
    Calgary, Canada
    Here here.
  7. Rebem
    Rebem Member
    Wow, that's a wealth of knowledge gentlemen! ;)
    Look out for the review when I buy one and see how they go. I might even post pics...
  8. Lightcs1776
    Lightcs1776 Active Member
    Upstate NY
    The only down side I see to the digital manometer you provided the link to is that you can only connect two carbs at one time. You can get the carbs in sync, but will have to be swapping hoses as you go through the carbs. I use the Morgan CarbTune Pro and like that I can connect all four carbs and quickly get them in sync.
    JeffK likes this.
  9. Rebem
    Rebem Member
    Totally agree but the Morgan is nearly 3 times the cost. I can't imagine having much use for either the Morgan or the digital manometer other than the odd carb sync, so the cheaper the better.
  10. Polock
    are you sure that will work? +/- 2psi doesn't seem like enough range.
    maybe someone with a gauge remembers what numbers they saw
  11. waldreps
    waldreps Active Member
    Henning, MN
  12. mlew
    Apex, NC
    If you bench sync the carbs first like you are suppose to it won't be a problem. Remember it will be reading differential pressure. My gauge reads 0 to 15 inches water and if properly bench synced it will come close to pegging the gauge.
  13. k-moe
    More tubing, t-fittings, aquarium filter valves. All carbs can then be hooked up, and you can switch which ones that manometer is reading from as you work.
    Lightcs1776 and Rebem like this.
  14. k-moe
    2 PSI is 4" of HG, and 55" of H2O. Plenty of range.
  15. Rebem
    Rebem Member
    The digital manometer was delivered to my office today and was met with many humorous comments about what the "man-o-meter" actually measures. Here's a quick photo. I'll post details when I give it a go on the XJ.
    XJ550H likes this.
  16. Wintersdark
    Wintersdark Well-Known Member
    Calgary, Alberta, Canada
    Here's hoping it works well. At that price, I'd happily grab one too. $35CDN... Hell, making myself a DIY one would cost just about as much =/
  17. Polock
    how did this thing work out ?
  18. Rebem
    Rebem Member
    Bit of a long story but in the end I took the bike to a shop with experience (in XJs) to do the final tune on the carbs. It's running really nicely so I'm happy. Rode it to work today for the first time!
    When I did hook the digital manometer up to the bench synched carbs, the readings fluctuated wildly and even beyond the scale of the meter at times. It was hard to get a real visual of what the problem was, or which carb I needed to adjust. This is the advantage of a normal manometer because you can see variance quickly and work out what you need to do - no interpreting numbers.
    Stumplifter and Wintersdark like this.
  19. XJ550H
    could be you need to do what has to be done for a vac guage add a connector with a tiny tube(orafic) like the straw from a can of carb cleaner to slow down the "jump"
    Stumplifter likes this.
  20. cgutz
    cgutz Well-Known Member
    SE South Dakota
    I like my big, 5 foot homemade manometer for this reason! I can see if from across the garage if necessary. (Actually, I lean it on the handlebars).
    Dadoseven and Stumplifter like this.
  21. Stumplifter
    near Irma, WI
    What was the total length of tube used on that?
    I.D. of tube?
    Smaller I.D. / or restrictors put on towards the carbs?
    T-Fittings at the bottom?
    My 2 bottle is cute and all but the idea of hooking up all 4 and doing them all at once is nice instead of Molly Putzing around to 1/2 then 3/4 then 2/3....
  22. Polock
    that must be like fiddle farting
  23. cgutz
    SE South Dakota
    5 foot 1x6. Tubing is screwed to board with plastic coax cable mounting tabs.
    Total length of tube is 9 feet. 8 feet of vinyl (can't remember size, next size up from aquarium tubing). Each tube connects to the carb with another foot of rubber vacuum hose to keep from melting.
    Two T connectors at bottom that fit the vinyl.
    I inserted a smaller size vacuum "straight through" connector into each vinyl tube just before the connection to the rubber vacuum tube to hopefully restrict air somewhat.
    Fluid is ATF.
    When I started the height difference was about 1 foot between high and low levels. Adjusted relative height of each carb to within 1/2 inch or less and called it good. Very small turns changes the relative height about 2-4 inches, so it is a bit sensitive. 9 feet of tubing gives a bit of "safety" for not sucking fluid into carb.
    Bike idles much smoother (and I no longer have the notorious XJ550 cam chain rattle from "lumpy" idle). Idles around 1000 rpm cold (70 degree outdoor temperature) without choke.
    Operating idle is between 1100-1200 rpm depending on how much it is warmed up. Idle after a half hour of highway driving on a hot day is about 100-200 rpm higher than in town warmed up driving, then settles back down after a few minutes of town driving. Is this normal?
  24. JeffK
    JeffK Well-Known Member
    Just North of Annapolis MD
    I've used my homemade manometer and my Syncpro for many years on many different bikes and no, you don't need the "yamaha adapters" to work on Yammy carbs but I have them anyway. I like seeing all four, incl the reference cylinder at once on my only 4 cyl bike. They don't work too well on all the two strokes <lol>which make up the bulk of my collection but I still do bikes for others.
    jeff
  25. Polock
    i used my two bottle job on my sv100s throttle bodys and that made a world of difference.
    i put some glitter in the water so it sparkles when it bubbles
  26. Stumplifter
    near Irma, WI
    Do you take it to Coachella and shake it around while dancing with glow sticks?
    Sorry, couldn't resist! :p
    Polock and Wintersdark like this.
