Funny Harley story
Discussion in 'Hangout Lounge' started by hogfiddles, Apr 8, 2017.
  1. hogfiddles
    a neighbor called me up this morning---"I got a likely sale on my '92 Sportster, but it wouldn't start when the guy was here....I told home I'd get it fixed.......can you come help me quick?"
    Me: "be right up"
    So, good battery, good fuel..... Turning over--but not firing. Pull plugs. Good spark. Starter fluid. Nothing. A bit more. Nothing. Put some in the cyls. Nothing. Try again......single pop. Try again. Big backfire. Pull plugs to see which is dry. Both. Put in a bit more gas. 1 pop and one small backfire from rear Cyl. Spray/squirt again but into the carb throat..... 1 pop, but a loud backfire from front this time.
    Friend,"gas isn't getting through the carb....."
    Me: "it is, I can see the vapor cloud in front of the carb".
    Friend: " let's pull the carb to make sure it's ok.......it's started fine three times during the winter, though....."
    Me: "got any new plugs?"
    Him: "wouldn't be the plugs, I could see spark........I don't have any, I'd have to get some, and they are Harley plugs, and they're not open now"
    Me: "ok, how about running just up to NAPA [5 min away],and just ask them for two of the equivalent ---- I'll go get my tools while you do that".
    10 min later........
    Put in the plugs, touch the button:
    "brumpity-brumpity-brumpity-brump-Brump-brumpty.brumpity........."
    Him:"SOB!!! That's all it was?!? hOw'd you figure that one out??"
    Me: just a little smirk
  2. Sieg
    Sieg New Member
    Leatherstocking Region NY
    I think I just learned a bit from that story. I will admit that after seeing spark I would have headed down the path of your buddy, wasting a ton of time. Clean carb though!
  3. hogfiddles
    As a snowmobiler, I can't even count the number of times a plug goes down, but you can see a free-air spark yet when it's in the cyl, it's dead.
    So, I will go to new plugs before doing much more, juuuuust in case. Often enough, there's the problem, and it's such a quick fix
  4. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    So why is that? Hot electrical system? Typical plug failure?
  5. k-moe
    Increased internal resistance/short in the plug due to age/ manufacturing defect.
  6. hogfiddles
    .... and running hours-on-end at 8,000-10,000rpm----
  7. lush90
    lush90 Member
    Outside of Seattle
    I have seen a YouTube video about testing spark plugs but have never actually done it. Would be interesting to know what is out of spec so a plug could be ruled out.
  8. hogfiddles
    Nothing was out of spec.
    You need three things for ignition: spark, air, fuel
    Air---that was easy, the engine wa sucking it in
    Fuel - that was easy......could see it, smell it, feel it
    Spark - you'd THINK its easy......pull the plug and see it spark. BUT-- you can't see it spark in the cylinder. It maybe shorting to the side under compression, or internally when in the cylinder. So, the way to try that is simple---put in new plugs. If it fires right up, you fixed your problem. If it doesn't, you know to keep working.
    When we're on a sled and blasting across a field, and all of a sudden you lose power;or you com to a stop, and you just sit there and bog when you try to take off again-----pretty good bet you dropped a plug. That's why we always carry several extras with us.......it's a common occurance
  9. Simmy
    At one time I rode an old 1980 Kawasaki Invader 440LTD with dual plug heads. NGK used to send me Christmas cards. When I hit the beach in the summer I looked like a hermit crab, huge upper body development on one side only from pulling that freakin cord so much.
  10. hogfiddles
    That was the two-tone blue sled, right?
  11. Simmy
    the LTD was dark green. Twin expansion chambers, each cylinder had 2 transfer ports branching into 3, that's what the 4/6 is all about on the hood. The last sled I had was a 1999 Polaris Indy 500 and I don't think it was any faster. The Kawi was a bullet for sure, ahem, once you got it started!
  12. hogfiddles
    My three favorite sleds I have are:
    1994 Polaris Indy 500 liquid - everyday ride
    1997 Polaris Indy 700 triple - when I want to ride fast...goes from 0 to bat-out-of-hell in about 3 seconds--or less
    1994 Indy 440 SuperSport - light and nimble to throw around
    Dave
    Simmy likes this.
  13. Sieg
    Sieg New Member
    Haha! My older brother had the same sled when I was a kid! I got a kick out of the pop-up headlight. They were all aluminum body, no? To this day my bro maintains that was on of the fastest sleds he ever owned.
