Where to place fuel filter?
Discussion in 'XJ Technical Chat' started by weoxstan, Jul 7, 2008.
  1. weoxstan
    weoxstan Member
    Central Michigan
    I have a fuel filter on my 650 and it is setting on top of the carb hats and the out side is kinda tilted up. I have not gotten it to fill up because of this tilt. This filter is about an inch in diameter and about 1.5 inches long, not including the hose connection ends. It seems to run just fine, but it makes me nervous with that tilt. Is there a better place to put it?
  2. wizard
    it is the only place to put it, unless you go the RickCoMatic / Stevensons rocket, external method.
    trimming the fuel line can get it to sit better.
  3. schmuckaholic
    California
    What you need to do is get the filter with the 90-degree barbs; fits under the tank better. Here's the one on my 750:
  4. maximike
    maximike Member
    Portland, OR, USA
    http://www.xjbikes.com/coppermine/displ ... =4684.html
    I haven't noticed if mine fills up, not sure if that's necessary, as long as gas is going through it, it sits fairly level, They didn't have a 90degree one, so I trimmed it until it was where I wanted. Had to re-splice part of line with brass fitting joiner thing.
    Measure twice cut once and all that.
  5. TheHound
    TheHound Active Member
    Scotia, NY
    The filter type in the picture above is shaped like a cone.
    If this filter is mounted on its' side the heavier material will fall to the wide part of the cone.
    Being gravity fed it doesn't get disturbed much and stays there.
  6. b0Rn2bL8
    b0Rn2bL8 New Member
    SF East Bay, CA
    here's my 2 cents:
