XJ700 *EFI* The holy sh*t it is fast now mod!
Discussion in 'XJ Modifications' started by gennro, Jan 2, 2011.
  1. darkfibre
    darkfibre Member
    Perth, Australia
    You wont fit them to 750 manifold boots, you need boots from the 700. Diameter and spacing is different.
    If you look up manifold boots on Lens XJ4EVER for sale section he has a good
    explanation of diferences.
  2. infamousalias99
    infamousalias99 Member
    but they will fit the gsxr manifold to the xj750 motor?
  3. infamousalias99
    could you possibly point me towards that write up im having a hard time finding it
  4. darkfibre
    darkfibre Member
    Perth, Australia
    This explains the differences in intake manifolds.
  5. infamousalias99
    ohhh haha i have 2 xj 750 motors. i should be able to mix n match boots to fit
  6. infamousalias99
    worse comes to worse i make something that fits
  7. darkfibre
    darkfibre Member
    Perth, Australia
    Just check to see that you can stretch the boots enough as they are smaller.
    I have decided to ditch the original manifolds and make an aluminium manifold instead for mine.
  8. infamousalias99
    i was thinking about making one but cost and time to my senior design project limited me to a gsxr setup
  9. zap2504
    zap2504 Member
    Middletown, PA
    Is there any definitive word on whether or not the Suzuki GSXR intake manifolds will fit the XJ650/750 heads, since the injectors are 33mm and the 33mm XJ700 intake manifolds are NLA?
  10. gennro
    gennro Member
    hhhhhhhhhhhhhhhhhhhh
    A heat gun, some lube, and two ratchet straps will make anything fit. It is not just a slip on affair. It takes some work to slip the throttle bodies in.
  11. infamousalias99
    Ive got a question about your fuel pump as well. the fuel rail that is on the gsxr setup doesnt have a return setup on it, and the pump i have puts out a straight 43 psi, is this an issue? how is your fuel system plumbed?
  12. gennro
    gennro Member
    I use a 2009 Honda rincon fuel pump that has its own built in 43psi regulator and return system into the surge tank the pump is in.
  13. infamousalias99
    hmmm ok, i think i may have figured out my system as well, its essentially the same setup without the surge tank.
  14. infamousalias99
    did you change your timing table since you first posted it? could you post it again if you did?
  15. gennro
    gennro Member
    The timing table is for a XJ700 it should be close to what you need for a xj750 with some tweaking.
  16. infamousalias99
    its almost identical comparing the one you have with the one in my manual
  17. gennro
    gennro Member
    Just a note: Make sure you separate the high current wires from the low current wires. What I suggest is put the grounds, injector, and ignition wires together then shield them. I also suggest shielding the 6 to 8" of low current wires also out of the microsquirt. This was causing all kinds of noise issues for me until I did this.
  18. gennro
    gennro Member
    Also another update: Have everything running great now! Updated my timing table. I'm pretty sure I have the timing set spot on to factory. Also added some closer resolution to the lower load and upper load ranges. Since I am running speed density for load I did that to keep the map signal from jumping around in the upper 80kpa+ load ranges.
  19. Zookie400
    Zookie400 Active Member
    Connecticut
    nice build!
  20. gennro
    gennro Member
    Yay did some cosmetic work today.
