what STUPID thing did you do with your yamaha today?
Discussion in 'XJ Technical Chat' started by uzivelli, Sep 15, 2008.
  1. Obiter_Dictum
    Obiter_Dictum New Member
    Winnipeg, mb
    I took it to a mechanic who asked me what a YICS was.
  2. photogin
    photogin Member
    wow if they dont know what yics is id get out of there.
  3. McGyver
    McGyver New Member
    I mounted an ammo box, outfitted with a back rest, just behind a chopped up drivers seat. Added lately: Vetter Vindicator fairing with almost 4 inches chopped off windshield and removed lowers for added ventilation on hot days, a 100 watt stereo with MP3 input, aux lighting on front forks.
  4. doc2029
    doc2029 Member
    Richmond, Va
    ummm, yeah I gotta hear the rest of this story!
  5. doc2029
    doc2029 Member
    Richmond, Va
    I would say that unless you find a long time Yamaha mechanic most will not know what it is. Like I believe Fritz said, when you get a 30 year old bike it is mostly DIY.
  6. gman
    gman Member
    Grand Rapids Mi
    Three things happened at once. Stuck float in the carb we didn't notice, stuck intake valve and using a can of ether to start it.
    Gas puddled in the air box, engine shot fire through the stuck intake valve back to the air box, igniting the gas and the ether was the frosting on the cake to add a nice Hollywood effects fireball.
    Thankfully it was more fuel than bike that burned, even though the airbox looks a bit warped. One of the wires on the new fuse block I installed burned off.
    Another forum poster here has christened the bike "Fireball"
  7. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    Hey, thought the deal was that I'd get creds if that name stuck? :twisted: :twisted: :twisted:
  8. gman
    gman Member
    Grand Rapids Mi
    Yes you get credit. I plead CRS for not mentioning your name.
  9. Militant_Buddhist
    Militant_Buddhist Member
    Redmond, WA
    A buddy gave me some fairly cheap grip heaters to test and see if he wanted to bother installing the same on his bike (he and I have inverse amounts of spare cash vs time and ambition)
    Wired them in to the ignition relay so I couldn't accidentally leave them on and kill the battery (smart) using a piece of wire I happened to have around that seemed about the right length. Got all the connections soldered and heat shrunk and started tucking and zip tieing and discovered that bit of wire was just BARELY long enough to install the heaters and not tug lock to lock (lucky). Tested to be sure they came on when they were supposed to and didn't when they weren't (switch for heaters AND key on = heat. Key off = no heat) Wrapped one heater element on the bar, used the piece of giant heatshrink that came with, reinstalled rubber grip. Moved on to throttle side. Discovered the elements are just like grips. there is a big one and small one and I'd already put the big one on the small side. Decided to proceed. Heat shrunk it on and while checking for slack to allow twisting discovered it really needed adhesive to keep from spinning when the throttle gets twisted. Managed to slide it off, spray glue and slide back on. Grip on.
    Final test fully installed. Key on, switch on... Wait for heat to make it's way through the rubber grip. Nothing. Killed some time by swapping in some LED tail light bulbs I had laying around. Come back, still no heat.
    Got to thinking this "deal" on cheapo parts wasn't such a deal (I already had to re-solder the switch that came on them. Started thinking how I was kinda tired and didn't want to take them off but really didn't want to just leave 'em either. About an hour start to finish now, half of that waiting for these things to heat up. In the initial test they came right on and I could feel the elements get warm right away.
    Oh what's this? killswitch. a minute or so later they were noticeably on.
    sposeda be sunny and warm tomorrow so a real review will have to wait.
  10. Ground-Hugger
    Ground-Hugger Member
    Near Port Dover Ontario
    Nothing yet but the day is still young!!!
  11. ajosephjohnson
    ajosephjohnson New Member
    Memphis,TN
    I was changing the oil getting ready for a 600 mile trip up north. Somehow I punctured a hole in the oil pan when I was wrestling with the drain plug. Now it sprays and I couldn't go on my trip. Haha maybe for the best.
  12. maximike
    maximike Member
    Portland, OR, USA
    Not today but yesterday, got up early to move it out of metered parking, so I wouldn't get a ticket. Moved it to residential area that requires permit, got bigger ticket. On my way to ride it (not knowing I had a ticket waiting for me) gas pipes sticking off of a building knocked my helmet out of my hands. So as I get to bike, angry about scratched up helmet, see ticket, angrier, put helmet on...old guy all the sudden has a camcorder, wants to take video or pictures of my bike, or me, or god knows. I can't hear him, try to play nice and smile for a picture. (he knew I was angry when he came up to me, heard me muttering about murdering meter-maids)
    He keeps talking and pointing, like giving directions, I can't hear a thing between helmet, engine, and plug-style ear phones (not for music, that's illegal;) for hearing protection) Finally, I just say, "sorry, man, gotta go" and ride off. Really, bike is pretty and all, but papparazzi?
  13. johnny77
    johnny77 Member
    north central pa
    Stupidity was yesterday remorse is today. Running at 55-60 yesterday a deer jumped off a high bank I'm driving on a freshly chipped road. You can guess the results. Police report said hit dear, slid on gravel, laid bike down This I knew expected damage didn't know semi runs over bike lots more damage. Today looking my girl over all the lights gone, broke the forks, frame, tires, rims and engine case.[​IMG] [​IMG]
  14. bmarzka
    bmarzka Active Member
    Northwesten PA on Lake Erie
    Count your blessings.
    The truck didn't run over you.
    You're still alive and able to make this post.
    Five years ago, I hit a deer with my Maxim. Spent 6 days in the hospital and then 6 weeks at home. Stupidity? I don't think so, just extreme bad luck.
  15. quebecois59
    After doing some work on the valve cover, I put the fuel tank back on and tried to fire the engine with only the vacuum hose connected to the petcock...vacuum works allright, I got fuel all over the engine!
  16. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    That will make you find religion quickly. Someone was certainly looking out for you.
  17. RonWagner
    RonWagner Member
    Didn't ride to work today and it is beautiful outside.
  18. ryancdossey
    ryancdossey Member
    Indianapolis, IN
    Blew my main fuse.
  19. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Stopped riding, to go into work...
  20. Mikko
    Mikko Member
    Finland
    Lost my gas cap key :x
  21. motors-guitars
    motors-guitars Member
    Noblesville, IN
    don't you mean VALVE COVER gasket? if your head gasket is leaking id fix that asap. my valve cover leaks a tiny bit just occasionally leaves oils on engine fins
  22. Polock
    i got a piece of old carpet and laid on the floor to park on so it's tires would be warm and cozy this winter
  23. sektorgaz
    sektorgaz Member
    Western MA, United States
    lol... wait, that's pretty smart :)
  24. Mad_Bohemian
    Mad_Bohemian Active Member
    Ravenna MI
    ...park... warm and cozy... WINTER... 8O how dare you say all those nasty things in one post!! lol
  25. hogfiddles
    Dang...........wish I had spotted this forum a couple weeks ago----I was unloading my 700 from the back of the truck. Just as the front of the bike got to the end of the truck bed, I moved the wrong way and bumped the support for the cap door. Now I have a nice white zig-zag scratch all over the otherwise perfect red front fender. Fortunately, I was far enough back that the fender is the only part the got hit. So, during the winter I"ll search out another perfect red fender..................
    Dave F
  26. bigfitz52
    Seriously.
    Even in stinky ol' PA it's still summer until the 22nd; and the leaves haven't even turned yet. You do still have a few trees if I remember correctly.
    I don't know about you, but I LOVE "color touring" when the trees are bursting with color and the air is cool and clear and the bike just loves to RUN. No oppressive summer heat and humidity, just the snap of fall in the air and some clear blue skies to split.
    I'll probably do more miles in the next month and a half than I have all summer. It's nowhere near as much fun riding in full gear when it feels like a dryer blowing on you.
  27. SLKid
    SLKid Active Member
    Troy, Va (Charlottesville)
    Stupid?
    Hah!
    I was riding with a buddy of mine and his brake light was stuck on. Was gonna fix it this weekend for him. Just didnt have tools on my bike yesterday
    Well I was listening to his engine to hear when he was slowing down, shifting, etc.
    Hes leading us out of a city Ive never been before
    Accelerates, grabs another gear, starts to rev up then BVVVV, revs down and downshifts. He had realized at the last second he needed to make a right hand turn. No brake light, no indicator
    Well my butt had already grabbed 4th gear and revvin up to catch his 900 like always cause he rides hard. 7k rpm 55mph (at least)
    Pulled in the clutch SLAMMED the brakes slid sideways (flat-tracked) for 20 ft downshifted twice feathered the clutch and throttle and effortlessly made the turn. Didnt. Miss. A. Beat.
    Dirtbiking made this possible. I wasnt even scared. Adreneline was pumping hard though. I slide all the time in the mud and just KNOW what to do.
    Thank goodness he was aware of me from the squalling tires and didnt finish his right hand turn. He would have creamed us both from the left. Most fun Ive had on a street bike in a while though ha!!
    Stupid cause I was following too close.
    But man what a rush
    -Chris
  28. jmilliken
    Dillsburg, PA
    I DIDN'T ride today.....
  29. hogfiddles
    Ding Ding Ding......and we have a Win-nuh!!!!! ......didn't ride today-----that's REALLY stupid. LOL :lol:
    Oh.....wait--neither did I. Now THAT was really stupid. ;)
  30. z32800
    z32800 Member
    Wellington New Zealand
    Great day here in Wellington NZ and I didnt go for a ride!!
  31. Tim morris
    Tim morris Active Member Premium Member
    Hopatcong NJ 07843
    Just dropped my xj while trying to put it on center stand with bad knees broke windshield deviated
  32. Tim morris
    Hopatcong NJ 07843
    Any one know how to get a new one
  33. k-moe
  34. Jetfixer
    A month ago pulled bike out of garage side stand down...or so I thought:rolleyes: down she goes...boy am I glad I bought the crash bars only damage a scrape mark on rear turn signal, and the clutch lever had a scrape on it. Spilled a bit of gas out to. Needless to say I double check it alot closer.
  35. Crimson9mm
    Crimson9mm New Member
    Tonawanda ny
    got everything laid out (tools petcock fuses(going to put inline blade fuses in for now since i had a few laying around.)) skip to last friday, 15mins before work ends...slice left index finger open... stitches come out friday....
  36. Jetfixer
    So this happened in February...bike put away for winter got in 40's ..try to start bike no go ..spray a little carb cleaner in airbox..starts and dies ...I then spray ether into airbox starts up next thing is a fire under bike..grab fire extingshiser ( big mess) the ether had leaked on to exhaust and a back fire through airbox..instant flame..still cleaning out the extingshier crap. Lesson learned ...don't use starting fluid..and have water standing by instead. At least I did not burn bike and house down ..o_O
  37. k-moe
    You were right to use the extinguisher. Water would have caused more problems. Ether (what starting fluid is mainly composed of) fires do not extinuish with water; they spread and get bigger.
  38. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    I got one for you. I went to check the oil level before leaving for work unscrewed the oil cap and set it on top of the clutch cover. Added oil as needed. Went to work and then back home 72 kilometers and pulled into the garage to look down and see that the oil cap was not in it's place. Be leave it or not the cap was still sitting on top of the clutch cover. Got lucky.
    Tim morris, Kevin A and Jetfixer like this.
  39. k-moe
    I let mine sit in the garage all day. :(
  40. lostboy
    I can not believe I did not get oil all my right leg.
    Jetfixer likes this.
  41. k-moe
    The clutch cover is well baffled.
  42. Taylo105
    Taylo105 Active Member
    San Diego CA
    Ran out of gas in the middle of rush out traffic and had to push the bike uphill to get to the shoulder. What a work out.
    Thought the reserve tank had a little more storage capacity... Lesson learned
  43. Tim morris
    Hopatcong NJ 07843
    Co 2 only
  44. Tim morris
    Hopatcong NJ 07843
    Smooth ride
  45. a100man
    a100man Well-Known Member
    Bedford, UK
    Went for ride to see an old pal. Got there and back 65 miles then stalled on my doorstep . Total electrical failure . WTF. check fuses, ignition connections headlight bowl apart etc.. etc.. all good check volts at fuse box good. Decide its the starter relay and take it off to examine. Break it taking it apart ! Next day decide to check starter motor and discover loose battery connection . Get on ebay and buy new starter relay..
  46. Tim morris
    Hopatcong NJ 07843
  47. Tim morris
    Hopatcong NJ 07843
    Got a great one for 6 buck's on ebay from China but it works well
  48. DrewUth
    DrewUth Active Member
    South Jersey
    Not really me, but....for the second time in a week, started it up in the morning to see puffs of fiberglass insulation squirting out of the pipes. F@#$ing mice! This is on top of the nest they made in my toolbox AND under the cowl of my 9.9 Evinrude. WAR is ON.
  49. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    Checked my valves. All were in spec. Put the valve cover back on torque all the bolts down and snap on the last one.
  50. Wagy
    Wagy Active Member
    PA
    I can beat that, just spent almost a week rebuilding in-line 4 carb ( I mean every nook ,cranny and jet) finally putting an awsome clean carb back together and was not paying enough attention when I dropped the needle assembly down the shaft . Well the needle(s), "yes all 4" stopped on the edge of the main jet nossel so I just cranked down the new stainless bolts ( just for looks) and then looked to see if the plunger was going to slide nice and free like a brand new carb should. To my shook, I had bent all 4 needle points into a perfect 90 degree angle LOL, maybe not so much ! So tomarro it's off to the Yamaha shop to buy new needle valves. Yuck it up everybody, I'm a dumb ass !
    DrewUth, TheCrazyGnat and Jetfixer like this.
